Hi, I am setting up avi files to make into a dvd on ulead dvd workshop, i usually use MpegVideoWizard to convert them to mpeg-2, and then set the files up in ulead dvd workshop and they author sooooooooooooooo fast cause the program dosent have to convert the file i loved it, then i tried avi2dvd(givesgreat quality) and converted them to vob files then i just rename the vob file extension to MPG, and set them up in ulead as usual and the program does the whole coverting thing takes forever! why???? i read somewhere that vob files can be renamed to mpg and still read fine cause they are basically the same thing...............so why is the program coverting the files ????
also what is a quick way to convert avi to mpg 2 fast??
thanx in advance!
Closed Thread
Converting VOB's to MPEG 2
By HitTheRoad in forum Video ConversionReplies: 9Last Post: 9th Aug 2011, 04:46 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 17:12 -
Converting .VOB to MPEG-2
By PHNeedsHelp in forum Video ConversionReplies: 2Last Post: 21st Jul 2010, 12:22 -
VOB/Mpeg to AVI??
By Rjupiter in forum Newbie / General discussionsReplies: 10Last Post: 20th Jul 2008, 08:00 -
Vob to mpeg-2 question
By ChrisXP in forum Newbie / General discussionsReplies: 4Last Post: 6th May 2008, 23:16
