  1. I have PIONEER DVD-RW DVR-105 and LG GSA-4167B 16X Super-Multi Internal DVD Writer.
    I don't know if I have to blame them, or media, because I am having lots of trouble with my DVD's. Even if I played dvd's or not, in time I see degrevation and dvd's become jerky and stop playing after a while.
    So:
    1. I decide to buy DVD Media Taiyo Yuden DVD-R 16X , which I have them already
    2. Decide to change the burner , but I don't know to which one.
    So my question is which is the most reliable DVD Writer in the market who can burn media and makes you to feel in safe with them ?
    Thank you very much
  2. Originally Posted by JimJohnD
    Thank you, but I need a different opinion then that list. I need to know in time if burned DVD's are still ok.
  3. Member JimJohnD's Avatar
    May 2001
    Ohio U.S.A.
    http://www.vso-software.fr/products/inspector/inspector.php
    Freeware app you can use to scan burnt DVD for errors.
  4. Originally Posted by icevideo
    That Pioneer 105 is a little old but the LG 4167B is a very good writer if you stick to high quality media. I prefer TY 8x +R (Yuden000T02) and -R (TYG02). The media you purchased is (guessing) TYG03 which I have never used. I would assume it to be very good. Make sure you update the firmware to DL13 if you are using new media like the TYG03.
    Good luck.
  5. Look at what the duplicators recommend. The NEC and PIONEER by far are the most common used. I personally use 3 Pioneer 108's and 4 pioneer 110's in my duplicator.
    Texas
    I would go with an NEC 4550/4551 or Benq 1650/1655.
