I was trying AutoGK last night. Installed it, put in a DVD, and let it to run overnight.
This morning, I found out that I didn't go through all the "first run" notices in VDubMod, and thus, it only just then started encoding. :P
I was doing something else on the PC at the time. I think I played with the "priority" setting a bit too much, and VDubMod crashed. AutoGK, which didn't know any better, thought the whole thing was finished, even though I only got 50% of the movie, and this was a 2-pass XVID encode! It's an almost 2 hour movie, so encoding time, even on this machine, is close to 2 hours for each pass.
So I'm faced with the prospect of rerunning the entire AutoGK job... Or somehow locating whatever "script" that AutoGK used to run VDUBMod, and re-run that.
I started going through my AGT_TMP directory, and found this VCF file, which contains the script. (Incidentally, VCF is also extension for Virtual Business Cards, used by Palm Desktop and other mail programs). So I try
virtualdubmod.exe lastjob.vcf
Got "unknown format"
Read up the command line parameters a bit. I need /S
virtualdubmod.exe /s lastjob.vcf
Got "cannot load script", then "unknown format"
Must have tried a dozen different variations, this directory vs. that directory, quote vs. no quote...
Until I realized there must NOT be a space between the /S and the script file name. The Help File didn't REALLY say that. I found that on VirtualDub.Org.
So I fixed that, and I'm encoding again.
So it's not a question, more of a tip on "how to recover from AutoGK crash". Hope this is of some use to others.
Results 1 to 1 of 1
AVI sync; tearing my hair out!
By Rekusu in forum Video ConversionReplies: 10Last Post: 11th Apr 2012, 01:23 -
[SOLVED] Tearing my hair out over this... muxing unmuxing..
By Leijonasisu in forum Newbie / General discussionsReplies: 3Last Post: 13th Oct 2011, 02:05 -
Tearing my hair out trying to convert HD movies for Xbox 360
By gers1978 in forum Video ConversionReplies: 5Last Post: 4th Oct 2011, 07:30 -
Hair tearing H.264 and .mov problems!
By Nintendo Fan in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 2nd Mar 2009, 16:16 -
Authoring while tearing out hair
By GimpGuy2000 in forum Authoring (DVD)Replies: 3Last Post: 7th May 2008, 02:58
