  1. I'm planning on using VDUBMOD to convert some vob files to divx and there is a filter in there for smoothing which I believe is used with lower bitrates to get a better image but how much smoothing should I use during the conversion? It goes from 0 to 100 and I'd rather not waste a lot of time trying different numbers. Any ideas what a decent setting would be?
    Apr 2004
    Miskatonic U
    Trial and error is the only way. There is no perfect setting, as it varies from source to source. Just remember that smoothing kills detail, which may save you a little bit rate, but will very quickly make your video look very plastic and artificial.
    Read my blog here.
