I'm interested in getting a Bravo, but they're out of my price range for the DVD recorder. However, I see some CD recorders on ebay for much cheaper. Could I just swap out the CD burner drive for a DVD burner?
I have the one with just the printer. I also thought about that very thing. I am no sure whether the SW for the CD one will work with the DVD.
No DVD can withstand the power of DVDShrink along with AnyDVD! -
the dvd burner comes with the usb + firewire
doesnt the cd burner only have usb ?
if it has both -- it might work ...... maybe .... (try at own risk)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
the dvd version btw uses (at least it did) primo dvd version 2 with one added file ... it is a dll file and can be dropped into any install of primo to control the bravo (i had one and tried it)
Bravo SE Disc Publisher
By 16/9 in forum DVD & Blu-ray WritersReplies: 0Last Post: 18th May 2011, 05:40 -
Need help with upgrading
By jaywestcwf in forum Capturing and VCRReplies: 2Last Post: 10th Feb 2010, 10:19 -
help reqd. in upgrading firmware of my DVD player
By mohit in forum DVD & Blu-ray PlayersReplies: 2Last Post: 15th Nov 2009, 10:17 -
What needs upgrading on my p.c
By minidv2dvd in forum Newbie / General discussionsReplies: 1Last Post: 23rd Jun 2009, 15:12 -
DV-400 : After upgrading FW, holding ENTER does not make DVD regionfree
By ricardonovo in forum DVD & Blu-ray PlayersReplies: 0Last Post: 26th Mar 2008, 15:33
