Hi, Before I consign my faithful Tosh to the dustbin I wondered if anyone could suggest why it won't play any discs. It just comes up with disc error. I have cleaned the lense and all seems to be ok inside i.e no black charred bits! so I have run out of ideas of what else may be wrong. I have a reasonable level of electronics background so any help is welcome.
Cheers,
Jon
Does it do any 'seeking' for the DVD tracks that you can hear, or does it just reject the disc immediately?
It could be a dead laser or if you hear a lot of seeking, a sticking laser slide. Does it play any commercial DVD or CDs? -
Hi,
Yeah it does do alot of seeking, you can hear the disc keep spinning up. It sometimes starts to play the intro to a DVD i.e. the MGM Lion bit and then stops and will not go any further onto the menu's. If it is the sticking slide etc. hows best to free it up?
Thanks in advance,
Jon
Which one is better? Samsung D392 (mini-DV), Toshiba P10, Toshiba H20...
By renavspainatal in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 5th Nov 2009, 09:59 -
ipod 160gig screen fault?
By angryassdrummer in forum Portable VideoReplies: 0Last Post: 7th Jul 2009, 00:45 -
Car radio fault
By didikai in forum Off topicReplies: 2Last Post: 26th Oct 2008, 17:17 -
Segmentation fault while executing dvdauthor
By mmasroorali in forum Authoring (DVD)Replies: 3Last Post: 17th Oct 2008, 19:33 -
fault on toshiba rd-xs24
By superray in forum DVD & Blu-ray RecordersReplies: 0Last Post: 20th Dec 2007, 07:31
