Excerpt from the DSFP codec pack
The file I got is a MP3Parse.ax exactly 100KB in size.(Extra Info)
Q:Rendering MP3 files is already possible with the standard MPEG-I Stream Splitter, why add an extra one?
A:The standard MPEG-I Stream Splitter, and the new MPA Splitter from Gabest, report incorrect VBR (Variable Bit Rate) MP3 file duration. The MPEG-I Stream Splitter also fails to recognise some MP3 files with non-MP3 data such as ID3 tags as proper MP3 files, hence failing to open them altogether. This extra MP3 Parser Filter fixes these issues.
Results 1 to 13 of 13
I don't know, I haven't tried it yet, as I don't have any AVI that has VBR MP3 soundtrack.
Can't see how it would make any difference. It is talking about regular mp3 files. With an avi file it would be avi splitter-->mp3 decoder-->sound renderer
For mp3 and other audio files I would suggest foobar2k anyway or some other more dedicated audio player like winamp or even itunes. -
and reguarding video, i'd advise against using vbr at any cost anyhow......or if you do, to just remux it with wav instead of vbr mp3.....particularly if your intending to reencode it....for playback though, just do like celtic druid says and use a program more specifically tailored to audio playback.....
I would definatly recommend VBR over CBR (for both movies and music). Much better quality. Just ditch avi and use a container that can properly handle it. That said, I never had any problems using VBR audio in avi.
If they play fine then they can be converted fine. The very fact that you can convert to pcm wav proves it.
Problem is, I have to go through this intermediate step because most encoders won't read them correctly. Some crash outright, some just have sync issues. Even audio software such as Sound Forge doesn't like them. So it's not that it cant be done, just that it takes more effort than it should. (That's without getting into the whole MP3 is an evil form of compression, period, conversation
Read my blog here.
SYNC PROBLEM: X264 AC3/DTS MKV --->>> Xvid with VBR mp3?
By Randm in forum Video ConversionReplies: 6Last Post: 30th Jul 2013, 17:57 -
Gordian Knot AUDIO PROBLEM: DTS to VBR MP3? (HD 720p.mkv to SD XviD.avi)
By Randm in forum Video ConversionReplies: 2Last Post: 31st Jul 2009, 01:49 -
Trouble converting VBR Ogg to MP3
By Ryutso in forum AudioReplies: 2Last Post: 3rd May 2009, 14:19 -
how to convert MP3 vbr to MP3 cbr?
By sumeshkri in forum AudioReplies: 2Last Post: 25th Aug 2008, 23:59 -
Avi.Net VBR MP3
By KnightHeart in forum Video ConversionReplies: 0Last Post: 8th Jul 2007, 06:40
