  1. I created a DVD from my VHS tape using a DVD Recorder. The process worked find but I want to add chapters to go to specific spots on the DVD. I purchased Adobe Premiere Elements 2.0. I produced a DVD from it and it was ugly bad... Waste of money.. of I did something wrong..
    I'm looking for a way to add chapters using the DVD I created using my recorder, it worked great to produce the DVD from VHS tape, I just want to add chapter and a Menu.
    Can anyone help, I did a search on the form but didn't find anything on chapters.
    Thanks.
    You need to reauthor the dvd. You can use tda, add dvd video and select the video_ts on the dvd. Create menus and chapters. Author and Burn.
    Or https://www.videohelp.com/guides.php?guideid=638&howtoselect=3;6#638
  3. TDA worked to add chapters. I would like to change the names from chapter1, etc. to something more meaningful. Is there anything else that will add a little extra to the DVD. I can live with this don't get me wrong I would just like to make it a little better.
    Thanks for you help.
    Found what I need in TMPGEnc it should take care og the problem.
    Thanks Again
