Anyone else have a problem trying to encode a ffmpeg Xvid with audio? I downloaded and installed 'v' three times and it still immediately erred out when hitting encode. Gives the 'number of output streams must match....' error. If you disable 'encode audio' it works, as in it begins to encode the video only. It also 'works' when trying to encode a .mov with AAC audio, but, that's only because it completely ignores the AACs existence and begins encoding the video only. It doesn't even see the AAC audio anymore.
What's Up? I re-installed 'u' and ffmpeg Xvid works again![]()
VOB to XviD ffmpeg goes well here, but an Apple movie trailer (h.264/AAC) fails on audio. The original multichannel audio gives a "Can't resample. Aborting."-error. If I first convert the audio (in QT PRo) to AAC, stereo, 48kHz, 128 kbps, then ffmpegX recognizes that as AAC, 96 kHz, 0 channels, which fails as well, obviously.
Adding a PCM stereo WAV audio track to the h.264 video then finally produces something that ffmpegX XviD ffmpeg will handle correctly.
Yeah, ffmpeg always had a problem with AAC audio, but that really doesn't bother me. I just threw that in hoping it might shed some light on the problem I am concerned with. The Xvid ffmpeg option is about the only ffmpegX .avi format that my Avayon Divx player works with. I use it to convert those Qpel encoded Xvid .AVIs that my player won't play. It use to work fine. Now I have this above problem trying to encode an Xvid/mp3-ac3 .avi to a Qpel-less Xvid/mp3-ac3 .avi. Can you try it with an Xvid/mp3-ac3 .AVI and see if it works for you? BTW, I'm not trying to encode 2 audio tracks, just one, using either mp3 OR ac3 audio 8)
WTF!!!
OK, I just installed version 'v' on another computer, tried a few movies, and found....
For some reason this error only happens if you select the 'Trellis quantization' option! If you DO NOT select Trellis, but leave everything else the same...It Works! TOO Weird! Again, this didn't happen in version 'u'.
ffmpeg encoding to xvid + ac3 5.1 -- can't make it work!
By suroit in forum Video ConversionReplies: 2Last Post: 4th Jan 2012, 17:13 -
need hq xvid ffmpeg preset for kdenlive, with deinterlacing
By codemaster in forum LinuxReplies: 0Last Post: 3rd Jul 2011, 01:56 -
Which ffmpeg build plays xvid in virtualdub after encode? ... [RESOLVED]
By vhelp in forum Software PlayingReplies: 1Last Post: 4th Sep 2009, 23:04 -
FFMPEG AVI (XVID) to IPOD Mp4, AUDIO OUTPUT is 2x Normal Speed, HELP!
By jiulonghks in forum ffmpegX general discussionReplies: 1Last Post: 21st Sep 2008, 00:35 -
Getting FFmpeg to use XviD codec with 4:3 instead of 1:1 pixel output?
By PBear in forum Video ConversionReplies: 7Last Post: 10th Jul 2008, 16:03
