  1. Hello,
    I recently purchased a G5 primarily for video eithing. My only problem is that the MAC software I am currently using (Imovie and Final Cut) do not have any "album transitons" like the ones available in ulead videostudio. I am working on a presentation for a 25th wedding anniversary and the album transition (Looks like your turning through pages in an album) would be perfect for this presentation. Does anyone know if there are any plugins available for any MAC applications that contain this type of transition? I will also like to hear any suggestions if possible. Thanks in advance.
    USA
    You would have better info in our Mac forums. Moving you.
    Dec 2003
    Eugene, Oregon
    You are looking for a specific iMovie or Final Cut plugin. Go to versiontracker.com and search for either iMovie plugin or Final Cut plugin and you'll see lots of sources for these.
    If nobody here knows exactly where to get that specific plugin you might post your question in the appropriate iMovie or Final Cut forum at http:discussions.apple.com
