Hey
I read that if you make a DVD image you can burn it to a
cd-r and use it like a miniDVD or cDVD. How do you make the DVD image? I have a DVD authoring program and nero, which one do I need to use to burn the DVD image to the
cd-r?
Thanks guys
Man you needs to lay off the herb...we discuss this already...use the DVD authoring to program to make the image and then burn the image with Nero...I hope you have one of the 2% of DVD players that will actually play this format...otherwise its a wasted exercise unless you watch it on your PC, even then, still a wasted exercise.
On 2001-12-29 20:02:11, smokingweed3000 wrote:
Hey
cd-r?
Thanks guys
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Try downloading the sample MiniDVD ISO image from here.
This way you'll know if your DVD player is compatible.
http://www.vcdhelp.com/minidvd.htm
Good luck!. Hope you can play it, because I can't, in none of my DVD players.
Windows7 image backup - restoring the image question
By ranchhand in forum ComputerReplies: 18Last Post: 15th Apr 2012, 07:13 -
Printed page image don't equal PC monitor's image?
By bryankendall in forum Newbie / General discussionsReplies: 9Last Post: 11th Nov 2008, 13:45 -
Vegas 8 - replace an image with image from previous frames
By sdsumike619 in forum EditingReplies: 2Last Post: 5th May 2008, 14:26 -
Vegas - add image to video (DVD(mpg)) and moving image around
By psxiso in forum EditingReplies: 4Last Post: 11th Jul 2007, 04:29 -
How to post an image instead of a link to image?
By fLYtRap in forum FeedbackReplies: 11Last Post: 5th Jul 2007, 12:55
