Just wondering whats the best way to do this. I use the coaxal plug(i think its called. I get picture, but no sound.
s-video would give me sound mabye..
help
S-video is picture only.
I would suggest audio cables, from the VCR into the soundcard as well.
Of course this all depends on what you are connecting to on your PC for the picture. How is your VCR to PC connected?Cole -
The questions meant what kind of capture card or capture device are you using?
The connector you are using now is called an RF connector and it carries video and audio but the quality is not very good. Your VCR should have a composite video output and maybe even a S-video output along with audio outputs. The composite video output is the "yellow" RCA plug and the audio is white/red for stereo or usually just white if it is a mono only VCR. The S-video connector is the one with the "pins".
My card is: ATI RADEON 9600 Series DDC Display
it has the yellow video cable in and rf modulater. And another thing..
I have no idea how to get sound. Video works but i cant get any sound... -
You need to connect rca connectors from your audio out L/R on your VCR, to your Audio in on your sound card. Then you need to change the setting in options or preferences, to tell your capture software which device to use for capturing sound, and set the appropriate input level on our sound card.
Rob -
Using the co-ax cable you're using the tuner on your aiw. Should have audio output if set up correctly. Wouldn't worry about other connection methods yet if tuner won't even work. Try going back through the initialization wizard, & checking in device manager, making sure everything's as it should be. SHould have 6 ati devices under sound. Make sure sound card is working and nothing's muted.
If you've got a retail model, Directions say to use the separate lineout cable from the breakout cable at back of your card, & plug it into line in for regular audio. If you've got a non-retail version, like the white boxed aiw 9600 xt's all over, they don't seem to have the same connector setup, but haven't seen a decent picture.
I did find in their docs earlier today that with the aiw 9600 upwards you didn't need to use the separate line-out cable, that if set up with the newer MMC versions (be careful of 9.13), audio was passed via the buss using wdm. I haven't tried this yet. Generally if you use separate audio cables you need them to go through the aiw for capture -- bypassing the purple plug won't cut it.
Computer video capture vs. vcr to dvd combo?
By Haopengyou in forum Capturing and VCRReplies: 24Last Post: 19th Dec 2015, 00:50 -
How to copy dvd movies to computer and build a liabrary on the computer
By robrpb in forum Newbie / General discussionsReplies: 3Last Post: 4th Jun 2010, 19:16 -
cannot copy files to computer or copy dvd
By moshik16 in forum Newbie / General discussionsReplies: 0Last Post: 14th Feb 2010, 17:09 -
Audio problems with captured video on computer
By seeviper in forum Newbie / General discussionsReplies: 1Last Post: 16th Oct 2007, 10:06 -
VCR to computer- some help getting started?
By ker-plop in forum MacReplies: 4Last Post: 25th Jun 2007, 10:56
