I have a movie in .bin and .cue. It is kvcd, how should i go about burning to a dvdr as my dvd player makes a lot of noise playing vcd, svcd etc..
Peace
Results 1 to 17 of 17
“He who makes a beast of himself gets rid of the pain of being a man.”
Nope. IsoBuster deals with bins directly.
/Mats -
what exactly does the error say? something about 23.97fps doesnt say too much.....
23.976fps mpeg1 is not dvd compliant. You must reconvert to 23.976 mpeg2 with 3:2 pulldown.
Whaat i really want to do is convert the video to 25 fps mpeg2, the audio is no problem.
Thanks for the interest fellas. -
you may be able to get by with dropping the files into dvdlab pro, however then the resulting dvd may or may not play in your dvd player........
Why mpeg2? The video won't get better. Author as NTSC DVD - your PAL player will prolly handle it with grace.
/Mats -
He does? Only thing I can see is:
It's the frame rate that's wrong, not the file type.23.976fps mpeg1 is not dvd compliant. You must reconvert to 23.976 mpeg2 with 3:2 pulldown.
/Mats -
My mistake.
Allrighty then, how do i convert to 25 fps? What is 3:2 puldown? -
Never done NTSC - Maybe someone more experienced with NTSC can help?
/Mats -
By the end of the conversion you will have an even worse result - even sync issues - bothering to convert. Consider your source: kvcd. It is a poor non-compliant video format that uses a non standard GOP template in an attempt to minimise encoding quality but still retain a barely watchable picture via some DVD players on a TV screen.
Actually it's the whole encodeMats:It's the frame rate that's wrong, not the file type.
https://www.videohelp.com/glossary?0#3:2%20pulldown3.2 pulldown -
That's just my opinion. Others may disagree. Those at http://www.kvcd.net do
If you really want to try it, there are some basic guides for NTSC-Pal conversions in the guides section. Have a read to familiarize yourself with some of the terms and post back - perhaps make a new topic. We can help with any questions after you have done a little bit of reading
KVCD
By Bat21UK in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2007, 16:31 -
2 hours plus on one kvcd - how?
By t41 in forum Newbie / General discussionsReplies: 1Last Post: 16th Sep 2007, 12:08 -
KVCD- to DVD question...
By marklight in forum ffmpegX general discussionReplies: 3Last Post: 12th Jun 2007, 01:30 -
Xvid to KVCD
By mjaeson in forum Video ConversionReplies: 8Last Post: 25th May 2007, 21:05 -
KVCD to DVD
By buttzilla in forum Video ConversionReplies: 2Last Post: 6th May 2007, 09:01
