Have any of you used the JVC DR-MV5S for over 6 months/a year? From various postings I've read the reviews are leaning negative. Any really satisfied users out there? I've had mine for a week and aside from the very poorly written manual I have not experienced any problems.
Results 61 to 71 of 71
Originally Posted by blank_dogWant my help? Ask here! (not via PM!)
Thanks for the quick response Lordsmurf. I was thinking that it may just be a perception thing. Everyone has different tastes. I'll just let my eyes decide this one. Just ordered from B&H
Funny how the JVC is considered a poor recorder on almost any other site on the web, but a couple of people here praise it and it's supposed to be the best recorder out there.
I agree, stay away from JVC, the problems are much more widespread then reported here, the Pioneer is a solid choice
Greetings,
I'm curious if anyone has tested the quality of the DV input on the ES20 when hooking up a camcorder directly to the unit. Since the DV port is an addition from the ES10, it might make a difference to those with DV ports on their camcorders. As I consider my next camcorder purchase, it's a selling point to me; that is, if it actually works.
Thanks and regards,
TK -
Gshelley61 tested the ES20 DV input here,
https://forum.videohelp.com/viewtopic.php?t=287428&start=0&postdays=0&postorder=asc&highlight=es20 -
Originally Posted by nicky57Want my help? Ask here! (not via PM!)
Originally Posted by DupMJ23
Your correct about that. The JVC does well with poor picture sources but even better with clean sources.
How you can use a stand alone DVD recorder and your Canopus 110
By fuzzblaster in forum Capturing and VCRReplies: 22Last Post: 3rd Oct 2010, 12:06 -
Stand-alone Recorder (video blocking signals)
By grom in forum DVD & Blu-ray RecordersReplies: 1Last Post: 19th Dec 2009, 03:19 -
Typical lifespan for a stand-alone DVD recorder.
By usually_quiet in forum DVD & Blu-ray RecordersReplies: 114Last Post: 27th Nov 2008, 21:21 -
converting to AVI or mp4 with stand alond dvd recorder..speed test
By diablo_ogre in forum Newbie / General discussionsReplies: 1Last Post: 20th Jul 2008, 09:55 -
Looking for a Stand alone, cheap, DVD recorder, timecode on screen.
By AtomX in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Feb 2008, 16:10
