I am using ProShow Gold to make a Photoshow on DVD....
After rendering the 60 min of video for over 4 hours, when it got to the burning stage my burner had a problem...
Now I dont want to have to re-render for 4 more hours...So I see in the Pro Show folder under the show I was working on I have about 10 .vob files. There is no option in ProShow to just burn using these files, so my question is how can I now burn these files to a standard DVD. Normally the programs I have used before create the VideoTS folder and I can just burn any copies I need with nero, I have never burned from these vob files though. Kind of silly the program doesnt give you an option to just reburn without re-rendering the whole show.
Anyway, any thoughts?
Thanks All
Just use any dvd burning program and burn the video_ts and audio_ts folders. You might have to put it in data mode to see the video_ts and audio_ts folders. Make sure you burn both to be 100% compliant.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Not sure what you mean...How do you put it in data mode? Right now all I have is a bunch of vob files
Wellll.... If all you've got is vobs, then something's missing -- either import your vobs to an authoring program that will accept them, or Pgcdemux to get the vid/audio out and use those to author without re-encode.
To tell if *everything* is there, put everything in a separate folder and try to play the DVD on Hard drive with either PowerDVD or Nero Showtime.
Nero itself doesn't care about the VIDEO_TS folder, & will create that for you -- just select DVD video files for your project in Nero, and select everything. Yoda313 suggested a data project instead if you had problems I think.
burning DVD from either .VOB or .mp4 files
By rosmari in forum DVD RippingReplies: 6Last Post: 16th Apr 2012, 12:56 -
Burning VOB files to DVD WITHOUT Menus Or Chapters
By mediachimp in forum Authoring (DVD)Replies: 5Last Post: 11th Aug 2010, 02:11 -
Burning DVD's after converting to .vob files
By Joyful Noise in forum Newbie / General discussionsReplies: 1Last Post: 7th Mar 2010, 00:37 -
HELP! DVD Burning VOB files doesnt work
By liam0114 in forum Newbie / General discussionsReplies: 3Last Post: 5th Aug 2007, 18:35 -
*S.O.S* No Sound when burning VOB-IFO-BUP Files to dvd
By Zaii in forum Newbie / General discussionsReplies: 3Last Post: 30th Jul 2007, 05:46
