sorry if this has been answered before, I couldn't find it using search, All i want is a quick and dirty way to tell if the source is PAL or NTSC? i used to be able to do it with powerdvd under information but since i switched over to videolan I haven't been able to find a function similar to the one in powerdvd...the souces are usually in iso format
TIA
Hi-
Doesn't it say in the NFO?
One way, although I don't know if it's "quick and dirty" enough for you, is to mount that ISO in DaemonTools, and open it in the virtual drive with DVD Decrypter in IFO Mode. The Streams Processing Tab will say either 720x480 NTSC or 720x576 PAL for the video.
PAL converted from NTSC source - Ghosting and interlacing
By OngekibouRekka in forum Video ConversionReplies: 7Last Post: 3rd Dec 2011, 13:20 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
Hauppauge PVR-150 (PAL Version) Recording NTSC Source: Impossible?
By darkarn in forum Capturing and VCRReplies: 53Last Post: 16th Aug 2010, 11:06 -
Video in PAL and Audio from NTSC source
By jairovital in forum Authoring (DVD)Replies: 30Last Post: 17th Jun 2010, 14:16 -
IVT with AVISynth of source that has both PAL and NTSC conversions
By csdesigns in forum Video ConversionReplies: 9Last Post: 10th Feb 2009, 14:15
