hello all,
i manage to create a nice DVD however i have a few problems
which i cann't find answer in the forums.
1) my DVD menu look cuted the down right corner of the screen menu
is misiing but in know it's exist beacue i have buttons there which are working. anyone know why this happen?
i used Tmpeg DVD author and by the way when i view the DVD in my computer it's look fine.
2) when i view the video in my television (the whole video or chapter) every 20 second it's like freez and come back again .. it is very anoying
it is impossible to watch a video like that.
again when i view it in my computer (using powerDVD) it looks fine
i used adobe premier pro1.5 to edit the video and tmpeg to compress it to mpeg2
anyone have an idea why this happen?
the dvd i created works fine in my pc but not in my DVD player- tv...
thanks in advance..
Tzahi
Your first problem sounds like overscan. TVs cut off up to 5% of the video at the top and sides of the screen. A computer monitor shows it all. You want to avoid putting any buttons, etc., near the edges of the screen. Subtitles have this problem all the time. The amount not shown varies with the TV.
The second problem with playing can be caused by several things. It might be your standalone player, try a different one. It might be the DVD media you are using, try a different brand. Or it could be something in the burning process that went wrong, or even a earlier problem in the creation of the DVD. But the first two items are the most common causes.
PAL/NTSC DVD/VCR combo that will play DVD+R's w/o A/V synch problems?
By wetcamelfood in forum DVD & Blu-ray PlayersReplies: 12Last Post: 12th Jan 2010, 16:25 -
DVD-Lab Pro: DVD-R DL burning problems
By jonghyunchung in forum Authoring (DVD)Replies: 3Last Post: 14th Dec 2009, 07:57 -
DVD Editing from Panasonic VDR-D220 Mini DVD and interlacing problems
By gbnz in forum EditingReplies: 3Last Post: 15th Oct 2008, 14:34 -
Sync problems while authoring a DVD with DVD Flick
By TioSolid in forum Video ConversionReplies: 1Last Post: 16th Aug 2008, 13:21 -
Help with audio problems on dvd-lab pro and / or subtitles on a dvd
By Jack the Ripper in forum Newbie / General discussionsReplies: 12Last Post: 7th Dec 2007, 18:00
