What exactly does it mean when it says in NFO's, 3.9mbps 9 passes?? Is tht good? what should i be looking for?
It means the video has an average bitrate of 3.9 megabits per second and was created using 9 passes. With multipass encoding the picture quality is refined with each pass. But beyond 2 or 3 you get vastly diminishing returns. So somebody really overdid it.
so am i right in saying that the higher the bitrate and lower the passes, the better the quality?
Is there anyway of checking this info when there is no NFO? -
In general, the higher the bitrate, the higher the quality. But there are many other factors that influence the quality. For example, some codecs require more bitrate than others. An MPEG 2 video at 2500 kbps will probably look worse than the same video encoded MPEG 4 at 2000 kbps. An MPEG 2 file with a variable bitrate will look better than another at the same, but constant, bitrate.
With multipass encoding, each pass adds quality to the result. Say a 2-pass encoding takes 2 hours and gives you 95 percent "quality". A 3-pass encode will take 3 hours and might get you 99.5 percent. A 4-pass encode will take 4 hours and might get you 99.95 percent. Etc. So the quality may be getting better with each pass but amount by which it is improving gets to be so small as to be insignificant. Whereas the time spent encoding is getting longer and longer.
Getting video bitrate
By grv575 in forum Video ConversionReplies: 2Last Post: 5th Jan 2010, 14:35 -
Video Bitrate
By HartsVideo in forum Video Streaming DownloadingReplies: 39Last Post: 9th Aug 2009, 03:35 -
Video Bitrate
By Nitro89 in forum Video ConversionReplies: 30Last Post: 11th Feb 2009, 08:04 -
Increasing the video bitrate?
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 15th Nov 2008, 07:31 -
Video bitrate after conversion
By vcd_user in forum Video ConversionReplies: 5Last Post: 16th May 2007, 09:21
