Results 1 to 14 of 14
    Feb 2006
    Can anyone explain the difference between these two? One major difference that I noticed is the lack of Audio options in VirtualDubMod.
    I've been following this guide re-encoding some avi files with seperate .sub/.idx files to be hardcoded subtitles with the VobSub filter.
    https://forum.videohelp.com/viewtopic.php?t=272736
    I've been using the Xvid codec with defualt configuration which is using single pass. Should I be using Two Pass (1st pass or 2nd pass)? The files are coming out quite considerably smaller than they are going in, which isn't neccecarily a problem for me but I dont want to be losing more quality than has to be lost. Any tips would be appreciated.
    Doc
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    The big diff is that VirtualDubMod accepts mpeg2 video (and that the menu options are att different places.) For pure AVI filtering and encoding, there's no practical diff. 2-pass usually provides better quality at a given output file size, but takes twice as long to do.
    /Mats
    Feb 2006
    So unless I'm going to be working with mpeg video Its best to stick with VirtualDub I'm guessing.
    I found a post that explains the optimal Xvid settings:
    Originally Posted by jagobo
    Starting with the defaults (press Load Defaults at the main Xvid configuration dialog): I usually use Xvid in single pass, target quantizer mode (constant quality) with a quantizer of 2 to 3 (lower number = higher quality), MPEG Quantization Matrix (sharper picture), no B-VOPs (some players don't like B frames, they're lower quality too), Motion Search Precision at 5 (pretty fast), VHQ mode at 0 or 1 (pretty fast), maximum I frame interval 100 (for better seeking).
    The problems I have with this is:
    I cant find where to change the quantizer mode to constant quality
    (allthough I have set it to 2)
    And I cant find an option to set "no B-VOPs".
  4. Xvid: single pass, target quantizer is contstant quality (as opposed to target bitrate mode which is constant bitrate). Just set the quantizer value to get the quality level you want.
    B-VOP control is on the dialog you get if you press the "more..." button to the right of the "profile at level" pulldown on the main config dialog.
    Feb 2006
    Alrighty, Looks like I'm all set for now. Thanks for the hand guys.
    edit: Looks like my file sizes are coming much closer to the originals.
    Feb 2006
    One question I forgot to ask:
    Is there any way to save this configuration as the Xvid defaults?
  7. Xvid remembers the settings automatically.
    Feb 2006
    This probably isnt the right section of the forums for this question, but since I have this thread going already...
    I have a movie that is split into three files. All the audio is AC3 format, but one of the files is 5 channel and the other two are 6 channel. I am trying to join these files. I tried using and AVI Joiner that I've had much success with but it doesn't like the different audio formats.
    The only way I see to do this is use Decompress.exe which comes with Avi2Vcd to decompress all the audio and reencode everything with VirtualDub.
    Is this the best way to accomplish this?
    Doc
    Feb 2006
    If this is the best way I figure I'll just use
    Video>Direct Stream Copy
    Audio>Full Processing (using AC3 5.1 Compression)
    and Append AVI Segment for the 2nd and 3rd parts of the movie.
    Feb 2006
    Small Problem. When I try to do what I described above, It doesn't give me the option for 5.1 Channel AC3 unless I check show all formats.
    I'm guessing PCM doesn't retain multiple channels and just puts everything into stereo. BAH
  11. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    True. You can't join AVis with different video or audio properties. But why are you joining?
    /Mats
    Feb 2006
    I dont like to have multiple files for one movie. I have a home theatre with a Dedicated PC with WinXP Media Center on it and rather than have it stop at 1/3 and 2/3 to load the different parts, I want it to play straight through with 1 click.
    I will say that this looks interesting though.
    https://forum.videohelp.com/viewtopic.php?t=290454
  13. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Wierd if different parts of the same movie are encoded differently!
    I'd settle for stereo audio for 'em all then.
    /Mats
    Feb 2006
    Its quite weird. I got them that way so I can't put any blame on myself. I'm going to give this Aud-X stuff a try and see what its all about.
