I kinda get the picture. Thanks for the response, mate.
I get this too since I make a lot of 3500k/s XVCDs. On my DVD player it runs at super clock speed. At first it'll say 1:04 or whatever in WMP and you can't serach through the file and burning that XVCD on a VCD can't fast forward. All you have to do it de-mux and then mux the file and it'll magically fix this problem. Still runs at super clock speed but who cares about that. To save time I just encode the audio and video seperately in TMPGEnc and then mutex them. It warns me about some crap but the file works better that way and I've never noticed any problems with it.
So am I right in thinking that one 60min VCD at 1500 will require/produce 2 x 30min XVCD at 3500 for example?
Yes. Although I'm not sure 30 minutes will fit on one CD at 3500k/s. I fit about 24 minutes and it's a pretty tight fit.
It's a toshiba SD-1200 http://www.vcdhelp.com/dvdplayers.php?DVDnameid=473&Search=Search&list=0
Although it's listed as only going up to 2500k/s XVCD it goes up to 3500k/s without any problems.
Output AVI from DVDFab has doubled the video
By alffan in forum Newbie / General discussionsReplies: 5Last Post: 1st May 2012, 01:56 -
Runtime error
By The Monarch in forum ComputerReplies: 4Last Post: 28th Feb 2010, 02:42 -
Video "doubled" on Avidemux's work screen?
By gastrof in forum DVD RippingReplies: 1Last Post: 26th Jan 2010, 11:19 -
Title Information Doubled-up using Linux DVD tools
By jblack in forum DVD RippingReplies: 0Last Post: 10th Apr 2009, 22:04 -
MPEG File Size and Runtime differ greatly. How to fix it!?
By prophecy202 in forum Newbie / General discussionsReplies: 5Last Post: 19th Jun 2008, 22:37
