I got a DVD from a friend and it has the menue which I want to be removed. I just want it so that once i put in the dvd the movie will start automatiacaly without the menues being in the way. Is there a way to make this possible?
I made a backup of the DVD and it is on my computer now. So maybe i can remove a video file to remove the menue. I dunno..
Open it in DVD Shrink and choose "Re-author" and choose just the main movie and burn to a dvdr.
An alternative to that method is to remove all but the VOBs for the main movie (VTS_01_1.VOB, VTS_01_2.VOB, VTS_01_3.VOB, and so on) and then follow the instructions here:
http://members.dodo.net.au/~jimmalenko/test.htm#ifoedit
Don't forget when using IFOEdit (or VOBEdit) to drop the progress bar below the visible area on your screen so that only the title bar is showing:
This makes it run MUUUUCH fasterIf in doubt, Google it.
Replacing the main video in a DVD
By DeathStalker77 in forum Authoring (DVD)Replies: 9Last Post: 20th May 2010, 16:17 -
Backup main movie from DVD9 to DVD5 with main & chapter menu's.
By ChibiTomo in forum User guidesReplies: 18Last Post: 18th Jan 2010, 19:27 -
How to full backup (no encoding) BR main movie, main audio with subtitles ?
By meico1234 in forum Blu-ray RippingReplies: 2Last Post: 2nd Feb 2009, 03:37 -
main menue & submenue are not working properly with GFD
By akakiami in forum Authoring (DVD)Replies: 1Last Post: 29th Sep 2008, 06:14 -
How to insert a video in a DVD that have menue without re-processing all?
By whenloverageswild in forum EditingReplies: 0Last Post: 26th May 2008, 07:47
