I am trying to join 5 Xvid's within AVI2DVD. However when it launches AVI-Mux GUI to join the files I get the following error
Sounds like someone encoded one of the videos with just a lowercase xvid tag. Is there anyway to edit the tag of the Xvid files so I can get them to match?"Can't Join Files - Video compression formats differ: xvid <-> XviD"
After messing around with the tools that came with XviD I figured it out! I will now share incase someone else has this problem.
Goto your XviD folder and fine Nic4CC Changer. Load the AVI file, and you can then change the 4CC code so they all match!
Cheers mates! -
Use AVI FourCC changer to change the Description code from "XVID" to "xvid".
There may also be differences beyond the fourCC, like resolution, audio codec, bitrate et c. that makes joining the AVIs impossible.
/Mats
Trying to encode a clip to XviD to join another using VirtualDub ...
By Phat J in forum EditingReplies: 21Last Post: 5th Jun 2012, 02:08 -
How to join back 2 xvid files encode by autogk
By warresg in forum DVD RippingReplies: 1Last Post: 6th Nov 2010, 02:59 -
Join Avi (xvid) files together
By SpyJoe in forum EditingReplies: 11Last Post: 26th Aug 2009, 17:44 -
LOAD CLICK AND LOW SOUND at join of 2 avi xvid ac3 using vitualdub
By hawklight in forum EditingReplies: 0Last Post: 15th Jul 2007, 08:44 -
I Can't Join 2 XviD Videos together!
By Nitro89 in forum EditingReplies: 10Last Post: 26th Jun 2007, 15:08
