I have several questions for ya'all on conversion... basically i have a bunch of video files i would like to put on a dvd...
--- when i use tmpgenc - on some files i get a msg "gop is too long"
--- how do I convert .avi to .mpg? tmpeng wont open a .avi
--- how do I convert .mp4 to mpg?
I searched for a while and found "mediacoder" and it appears to make a video file but it wont open in anything i have.
thank you much
allen
Results 1 to 12 of 12
--- how do I convert .mp4 to mpg? -
Originally Posted by kschang
Originally Posted by allen074If in doubt, Google it. -
The trial version has the watermark. If you purchase it, that version doesn't. There is also a freeware older version on the 'Tools' page, but it will only do 700MB max files.
The pixelization is usually from too low a bitrate or trying to compress a file too much. If you have a good quality AVI you shouldn't see that problem.
DivxToDVD is a simple converter that works for the average Xvid or other video file. If you have problems, then a dedicated encoder like TMPGEnc is a better choice as it has more adjustments for bitrate, etc. -
DVD Source Creator is a simplified version of TMPGEnc encoder. It should work for what you want to do.
TMPGEnc DVD Author is the program to create the DVD structure, menus, etc., and burn a DVD afterwards if you want. Both an encoder and an authoring program are needed to make a DVD.
If you look to the upper left, under 'What is' DVD, you will see information about the DVD file structure.
MP4 to avi without conversion?
By forcedv in forum Video ConversionReplies: 1Last Post: 14th May 2010, 19:02 -
Conversion avi - MP4
By condorsoaring in forum Video ConversionReplies: 5Last Post: 7th Oct 2009, 04:14 -
Tech. questions! avi/mp4 to CD to DVD?
By OverrRyde in forum Newbie / General discussionsReplies: 5Last Post: 10th Sep 2009, 19:22 -
Questions about MP4 Xbox360 conversion
By trooper11 in forum Video ConversionReplies: 6Last Post: 15th Mar 2008, 14:40 -
avi to mp4 conversion speed
By killcorvus in forum ffmpegX general discussionReplies: 1Last Post: 15th Jan 2008, 16:41
