i saw a guide for "Batch Convert AVI/OGM/MKV to DVD"
https://forum.videohelp.com/viewtopic.php?t=273886&postdays=0&postorder=asc&start=0
couldnt you just open wut ever encoder you have several times and encode a different file for each window at the same time? or am i just being stupid![]()
Results 1 to 10 of 10
ProbablyOriginally Posted by yuan861118
The point of a guide is to show those who don't know how to do it. That particular guide I believe uses some fancy scripts to automate the process a great deal, saving you the time of having to set up all the same settings in multiple instaces of the program. A number of softwares either don't like or are unable to be launched concurrently due to use of DLLs and other files also.If in doubt, Google it. -
This is pointltess. TMPGEnc has a batch encoding feature that is EASILY accessible. When you create your project and go to encode simply choose "Encode now" or "Create Another Project". Then when you get to the last one choose create now and it will encode them one at a time. TMPGEnc is intensice enough on your system as a single operation. If you open it numerous times each operation will bog the other down an make it take many times longer than normal. Plus it will bog your system down tremendously.
I experimented with multiple instances of encoders a while back and determined that it took longer for two videos being encoded at the same time then it did to do them one after the other and the resulting files are terribly fragmented on the hard drive. It's fairly easy to set up a batch file to execute succesive QuEnc sessions and of course, as mentioned, TMPGEnc has it's own batch function.
Buy My Books -
First you create your .avs files then you create a .bat file.
For example I open notepad and enter:
(It's not real clear, but everything after "Quenc -i ..." up to "... -close" is on the same line of text).Code:C: CD Program Files\Quenc Quenc -i "G:\Video\Source.avs" -o "E:\Destination.mpg" -b 6587 -maxbitrate 9000 -dc 10 -priority 3 -2 -mpeg2 -hq -vbr -noscene -notrell -cgop -interlaced -noextreme -gopsize 12 -maxbframes 2 -nocmatrix -aspectratio 4:3 -mpeg2mux dvd -audiocodec AC3 -audiobitrate 384 -bff -auto -close Quenc -i "G:\Video\SecondSource.avs" -o "E:\SecondDestination.mpg" -b 6587 -maxbitrate 9000 -dc 10 -priority 3 -2 -mpeg2 -hq -vbr -noscene -notrell -cgop -interlaced -noextreme -gopsize 12 -maxbframes 2 -nocmatrix -aspectratio 4:3 -mpeg2mux dvd -audiocodec AC3 -audiobitrate 384 -bff -auto -close
Then save it as "Encode.bat", (make sure you change the file type to "all filetypes *.*"). Then I just double-click it in Windows Explorer and let it run."Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
There's no "easy" way in TMPGEnc itself ..... but I'm sure I've seen a tool around here that can take a whole directory as input and automatically create the TBE file for you.
Cannot recall exactly where or what it's called though
EDIT:
Just DL-ed this and it looked good:
TMPGEnc Batch List Creator 3
http://www.videogeneration.com.au/batchlist.htm
I would suggest setting up one file exactly how you want them all and then saving the template to a custom template. Also be careful of specifying the root of any of your drives (for example, c:\) as the destination for your output files.If in doubt, Google it.
New batch encoding solution
By grv575 in forum Video ConversionReplies: 0Last Post: 6th Jan 2010, 17:58 -
Batch encoding .. HELP
By likwid8 in forum Video ConversionReplies: 6Last Post: 30th Jan 2008, 13:33 -
Batch encoding
By buddycat in forum Video ConversionReplies: 1Last Post: 29th Oct 2007, 06:12 -
Batch Encoding with tmpegc
By Shaba1 in forum Newbie / General discussionsReplies: 7Last Post: 15th Aug 2007, 08:38 -
Batch Encoding - TV Episodes
By redtrigger in forum Video ConversionReplies: 25Last Post: 9th Aug 2007, 11:54
