Hello, Im new here.
I have over 100 small video's and some large video's on my hard drive.
I would like to burn these to DVD's that will play on regular DVD players. I have "Nero 7".
The video file types are .avi, .wmv and I think some are MPEG (they open with InterVideo WinDVD, how do I find out what they are?)
From what I understand I have to convert these to VOB/BUP/IFO and then burn them to DVD.
How should I go about doing this? Should I use Nero 7 to do the conversion, chapters, burn, etc...? or should I use a different converter and then Burn them with Nero?
I dont want to spend any money on any programs though.
Thanks alot for your help!!,
Pilot_Guy
Results 1 to 10 of 10
"The Sky is not the Limit!!, Its our home!"
use a different converter and then burn them with nero 7. check the videohelp.com/tools for other converting tools and videohelp.com/guides on to do it.
hacking the Net using typewriter :D -
You're asking too much of Nero.
First thing you would want to do is segregate them by type. If in doubt, drop them into a program like Gspot to identify their filetype. Super works OK for WMV converting. For AVI you can use a stand alone encoder like TMPGEnc.
After you know the filetypes, you can set up your encoder(s) and convert them to MPEG format. This will take quite a while, especially if they have different formats, framerates, framesizes, etc. You want to look to the top left for 'What is' DVD to see what the DVD format specs are.
Then you encode to those specs and finally author them to DVD with a program like TMPGEnc DVD Author and burn them to DVD. -
Originally Posted by Pilot_Guy
Familiarise yourself with the glossary:
https://www.videohelp.com/glossary
https://www.videohelp.com/glossary?A#Author
To format video into a form ready to burn onto a recordable disc or to stream onto the Internet. VCD, SVCD and DVD Author is to format video into its standard file structure and also add optional menus, chapters, audio tracks, subtitles, slideshows and much more.If in doubt, Google it. -
I've been looking at the TMPGEnc series of products now.
So, I could use TMPGEnc XPress to convert all the files to MPEG?
Then I can use TMPGEnc DVD Author to create the DVD files?
Thanks!
I had to wait a day before I could post here, so I spent that time searching around, but I just didn't find quite what I wanted to know."The Sky is not the Limit!!, Its our home!" -
Are there any requirements for the "Source Files" to be used on DVD?
Some of the video's I have are small (320x240).
Also Im looking at the Guides for TMPGEnc XPress, but they dont really explain how to adjust the settings for each different source file.
Can anyone link me to the best tutorial for TMPGEnc XPress?
A good one for DVD Author would be great too.
Thanks!!"The Sky is not the Limit!!, Its our home!" -
http://members.dodo.net.au/~jimmalenko/AVI2DVD.htm is more of a guide for TMPGEnc Plus, but has a lot of good information in it that you may be able to relate to TMPGEnc XPress.
Converting .WMV to .AVI - What should I use to do this?
By Hank Kinsley in forum Video ConversionReplies: 3Last Post: 16th Oct 2008, 04:54 -
converting wmv to avi
By evile1690 in forum Video ConversionReplies: 1Last Post: 9th Jan 2008, 04:15 -
Help converting home movie dvd to avi/wmv for web
By dancingbear0420 in forum Newbie / General discussionsReplies: 2Last Post: 24th Aug 2007, 13:35 -
CONVERTING FROM AVI TO WMV or RM
By sunsound in forum Newbie / General discussionsReplies: 6Last Post: 19th Jun 2007, 03:17 -
Help converting .avi into .wmv
By Theros in forum Video ConversionReplies: 13Last Post: 5th May 2007, 18:10
