    Jul 2002
    Canada
    The good:
    Solid build
    Nice price for a Video player
    Very small
    Comes in a varaity of sizes up to 1 GB
    Internal battery; charges via USB
    The bad:
    Small screen (but you know that going into it)
    Package decieves the customer by stating it plays divx when it actually only plays them by conversion to the poor quality, low resolution amv video format like all those chinese ebay MP4 players.
    The ugly:
    There is *no* way to turn off the timer on screen when watching a video. I've even used no name mp4 ebay players that know how to do that. Contacted tech support and the rep knew all about it and mentioned that others have called in as well and they said they have no fix for this.
    The verdict:
    Back to Best Buy it went.
    D minus
    Day Dreamin' about John Waters...again.
    The Naked Gord Program
    http://nakedgord.blogspot.com
    Humour, Politics, Gadgets.
    Nov 2006
    New Zealand
    I think I might have a solution to the timer.
    Do you mean the screen turns off after a certain time while watching a video?
    What you have to do then is make sure you have your clock set up, then in your "system" menu, look for options like "black", "darkle" and "sleep". These will give you the options to turn off the black screensaver.
    There is more information at www.MyMPxPlayer.org as well.
    Hope that helps.
