When viewing the recorded programs on the PC I can see a line or two at the top that looks completely garbled, like random data. Of course you can't see it when viewing on TV since they overscan by some percentage so those lines get clipped.
I've observed it on almost all DVD recorders I've tried (Liteon 5006, Memorex 2002, Govideo VR1940, Coby DVD-R1200) with the exception of Magnavox MVDR-660. Some of them use LSI, some Mediatek chipset.
I wonder if those are the scan lines with the other encoded info in them (aka data lines like cable encryption, station information etc.) However I don't see those consistently on all channels and of course Magnavox doesn't have them.
Is anyone else seeing those lines? If so, any idea what those lines are? They are pretty annoying when viewing on PC.
What is your source? That is likely where the noisy lines are coming from. It is not uncommon for cable and broadcast TV channels to have some frame edge noise in the overscan area. Every program, commercial, etc. varies and sometimes will have this type of noies, too.
I notice that Directv has a garbled line usually on top of the screen when I capture to dvd.
Sounds like you are seeing the closed captioning data. It's not supposed to be viewable.
Darryl -
That is what it is, closed caption and other vertical interval data (like station name, program name, parental control codes, test signals, etc). The moving stuff is usually closed captioning data.Originally Posted by dphirschler
TV sets are assumed to be overscanned so this normally isn't seen on a TV although HDTVs often see it when an analog signal is displayed.
Computer display cards and software players often give you the option to crop the edges or "overscan".Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Yeah I figured it must be the data lines. The funny thing is that Magnavox is the only one that does not display them EVER. Every recording I made on it in all qualities had no lines. I gues they must clip it internally before recording.
How can I show subtitles on the the top line and on the bottom line.
By Dracko in forum Authoring (DVD)Replies: 14Last Post: 8th May 2014, 15:03 -
Blinking line of thin white dashes at top of screen
By turbines in forum Capturing and VCRReplies: 15Last Post: 25th Apr 2010, 23:05 -
RF Modulator with S-video line-in or composite line-in?
By Disco Makberto in forum RestorationReplies: 30Last Post: 24th May 2009, 16:11 -
Weird horizontal line on top of the black area when playing movies(screen).
By Nitrius in forum Software PlayingReplies: 2Last Post: 23rd Aug 2008, 14:12 -
Top of the line 20 x by Sony
By thebirdf in forum DVD & Blu-ray WritersReplies: 11Last Post: 12th Dec 2007, 22:35
