how did you make the dvd? or is it a commercial ripped dvd?
there are several other methods to reauthor dvds,
https://www.videohelp.com/guides.php?guideid=638&howtoselect=3;6#638 -
pete,
you usually have to give for this option it a real dvd video file. I think if you give it the vob id of the piece that you want you will find the audio there as well.
That is open up the VIDEO-TS folder and select the VOB file that you want.
Problem with DVD Author
By JCWBobC in forum Authoring (DVD)Replies: 1Last Post: 12th Jul 2009, 01:55 -
Tmpeg DVD Author doesn't like low quality captures?
By the wordsmith in forum Video ConversionReplies: 9Last Post: 20th Mar 2008, 06:30 -
Does TMPEG DVD author support multi VTS
By perfection in forum Authoring (DVD)Replies: 1Last Post: 31st Aug 2007, 16:19 -
why subtitles move with TMPEG DVD Author
By Konde in forum Authoring (DVD)Replies: 0Last Post: 22nd Jul 2007, 00:21 -
Trouble with TMPEG DVD Author
By acidcrash in forum Authoring (DVD)Replies: 3Last Post: 20th Jul 2007, 04:31
