hello i need help to understand this
i want to make Svcd and thats no problem
the problem is ihave got a svcd whit a superb quality
from a frend and it is 1 hour 18 min long and the file
is 787 mb large i dont understand a thing the cd is 80min
i have tried almost everything to do the same thing
on vcd its no problem but svcd big problem
i use nero to burn and rip with smartripper and convert white dvdx
i have capture a film with my capture card an remade it to svcd but it gets to big please help me before i become crazy
if i dont as all ready
kenneth
SVCD is encoded at a much higher bitrate than VCD. Generally, one can only fit about 50 minutes or so onto an 80 min (700 MB) disc. Get it?
Could be a multi pass vbr with really really low audio bitrate. I screwed up when i was making the matrix so I ended up with an svcd with 81 mins for cd 1, but surprisingly it looks really good, but it does have 2 pass vbr and an audio bitrate of about 96 (i think). It is possible but you would have to sacrafice lots of time for the extra passes and audio quality for it. In my opinion, its not worth the 25 cents you save for just using one cd, I use at lease 2 for every movie.
Good Luck! -
Oh yea, and the way the 787 mb file can fit on one cd is because it is a video file. The way it works for audio + video on a cd is 80 min is really 800 mb or 74 min will give you 740 mb of audio or video.
Not sure exactly why its that much lower with data, could have something to do with the fact that when you play and audio/video cd and its scratched you won't care too much, it will just keep playing with the errors (most of the time) but with data its must be more sensitive so if a file is corrupt you will know instead of getting a bunch of corrupt files off a cd. Of course thats speculation.
hope this helps
Trying to understand wrapper vs codec
By brassplyer in forum Video ConversionReplies: 1Last Post: 27th Feb 2009, 01:23 -
I Want to Understand the MAC Mystic
By SCDVD in forum MacReplies: 32Last Post: 24th Jan 2009, 01:27 -
Need to Understand about DVD Burners
By mn072065 in forum DVD & Blu-ray WritersReplies: 15Last Post: 20th Jun 2008, 23:40 -
need to understand 16:9 DV format
By jmwismer in forum Newbie / General discussionsReplies: 5Last Post: 28th Dec 2007, 19:47 -
trying to understand kbps??
By icucmerc in forum Video ConversionReplies: 6Last Post: 5th Aug 2007, 00:58
