Hi,
Please help me to join more than one movies to one in DVDlab pro.
I have movies with two or three VOBs. I want to join them in one.
If you import the first VOB, and selct the option to Demux, DVD Lab Pro will demux them into a single movie. Or you could use Rejig to demux them first, and load them into DV Lab Pro afterwards (the better option).
Read my blog here.
I have tried it but could not do that.
I have approx 3 vobs want to join in single movie as "Movie 1" how to do this -
Are they all from the same disc and part of the same movie ? Either of these tools should do what you want if this is the case. If they are simply three seperate movies in their own vob files, demux each one and join later.
You could look at vobedit, but remember that vobs contain more than just video, and can therefore be difficult to join if they come from different sources.
Where did they come from ? a disc, or something you have encoded yourself ?Read my blog here.
I have one dvd contains two movies, I have back up with dvd shrink, dvd shrink made several files including 3 big files which are for movie. I want to join 3 parts to one.
Why ?
The DVD specification says that no VOB can be larger then 1000MB. Any titleset larger than this will be broken down into smaller files (VOB files) numbered to ensure sequential playback. If you intend to put these on a DVD, don't change them, as authoring will just split them up again.
Shrink works in titlesets, so if you reauthor and drag in two seperate movies you will get two titlesets. Each titleset may conatin several vob files.
So how about you start again, and explain clearly what you did to create the VOBs, step by step, and what you are trying to get at the end of the process.Read my blog here.
how to rearrange the movies in dvdlab
By sumeshkri in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2010, 07:18 -
Reliability of DVDLab Pro 2
By Brainiac in forum Authoring (DVD)Replies: 2Last Post: 28th May 2009, 19:04 -
Subtitles in DVDLab Pro 2
By lorix in forum Authoring (DVD)Replies: 13Last Post: 13th Nov 2008, 15:09 -
DVDLab Pro 2 compile issues
By milofhead in forum Authoring (DVD)Replies: 3Last Post: 28th Oct 2008, 00:25 -
DVDLab pro -multiple movies-menu-objects-BTN number mismatch
By sumeshkri in forum Authoring (DVD)Replies: 11Last Post: 15th Jan 2008, 08:48
