I've got a DVD-R with some interlacing problems--these problems are with the MPEG-2 stream. Somehow it was encoded wrong, so when de-interlacing is running in DVD Player and VLC, the image appears interlaced.
I'm wondering if this is a field dominance problem? Is there anyway to set it otherwise, like with MyDVDEdit?
If your problem is simply an issue of interlace being reversed, this can be fixed. Now, I only know of a way to do it on a PC, using Restream. So if you can use a Windows PC, or load up VirtualPC/SoftWindows, then maybe you can get by okay.
BD incorrectly flagged as interlaced - how do I set to progressive?
By DragonQ in forum Blu-ray RippingReplies: 3Last Post: 18th Dec 2011, 08:29 -
CCCP installed Incorrectly
By Westie69 in forum Software PlayingReplies: 3Last Post: 29th Mar 2011, 13:33 -
Re-encode/Fix Interlaced MP4 (Film)
By Eva-Unit01 in forum EditingReplies: 48Last Post: 28th Aug 2010, 09:33 -
Converting DV to H.264 and comparing interlaced/de-interlaced
By amirh1 in forum Video ConversionReplies: 5Last Post: 23rd Jun 2010, 09:16 -
Change of Region Code incorrectly set on DVD player
By cashey007 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 12th Mar 2010, 21:12
