I am a bit confused. In my quest for new MPEG editing and DVD Authoring software I had settled on TMP DVD Author Pro. Then I saw Adobe Premier Elements 2.0. They are both the same price. The Adobe product has many more features for editing and the stats on the box states you can use it to edit, encode and burn DVD's. I know the capabilites of the TMP product as I have been using the trial version. In my searches on these forums I have read that the Adobe product will not "author" a DVD and I must use another product for that. The Elements 2.0 is a new program and I am wondering if Adobe added that functionality. What am I missing?
If at first you don't succeed, maybe failure is just your style.....
Most all-in-one tools can capture,convert, edit, author and burn. And Premiere Elements is an all-in-one toooooooool, so you don't need any additional tools to create a dvd.
http://www.adobe.com/products/premiereel/overview.html (DVD menus = authoring)
But test the trial first...the authoring part could be very bad. -
Thanks Baldrick. I did further research last night and found some reviews that confirmed Premier will indeed author DVD's. However, I also looked at the forums on Adobe's site and there were a few posts concerning poor quality output. I think I'll stay with TMP and get a more advanced editor as I learn.
My DVD Authoring software stopped working and had an "APPCRASH" error
By Blueknight in forum Newbie / General discussionsReplies: 6Last Post: 13th Jul 2011, 23:55 -
Unable to find "Play next clip" when authoring DVD
By zonag5 in forum Authoring (DVD)Replies: 4Last Post: 16th Oct 2010, 02:50 -
Question re "lossless" extraction of clips for later DVD authoring
By TURB0x in forum Authoring (DVD)Replies: 4Last Post: 9th Jun 2010, 05:08 -
Setting "top field first" flag without re-encoding/re-authoring
By Miles in forum Authoring (DVD)Replies: 2Last Post: 16th Jan 2009, 07:15 -
Update2: English version of "TMPGEnc Authoring Works 4" released
By roma_turok in forum Latest Video NewsReplies: 26Last Post: 13th Nov 2008, 01:03
