First when I try to convert the avi there is no sound, Then I tried to make a wav in virtualdub, That went ok, but when I then convert my avi with the wav file in tmpgenc, it goes wrong... In the begin the sound is ok but later on the movie the sound doesn't match the video anymore...
Can someone help me out here...
I had a very similar problem. V Dub would only cut like 25 minutes of audio the rest was no sound. If you use avi2vcd and decompress the audio it works really good. It makes a file about double its original (sometimes bigger) then use the decompressed file as your video and audio input in TMpeg and everything should be better.
baldrick: the original avi file is okay
a-lo: thanx i'm gonna try that now. -
a-lo:
Thank you, thank you and again thank you, it realy works now, no sound problems anymore and a great mpg file instead.
avi2vcd decompression is realy great....
Thanks again man...
Greetz Mr Gray
AVI to MPG Conversion Audio Problem - please help!
By Nuzy in forum Video ConversionReplies: 4Last Post: 17th Nov 2010, 22:34 -
demux/mux question about avi to mpg conversion
By ibzomie in forum Newbie / General discussionsReplies: 4Last Post: 4th Jan 2009, 13:53 -
mpg to avi conversion
By rwagar in forum Video ConversionReplies: 1Last Post: 27th Mar 2008, 22:27 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 21:50 -
TMPGEnc not working.. what else is good for avi to mpg?
By andre477 in forum Video ConversionReplies: 10Last Post: 21st May 2007, 01:52
