i want to create keypad lock to protect my films.but i think the guide at dvdlab is complicated .So anyone can show me a easier way to create keypad and if people want to see my film ,they have to enter the PASSWORDS.any help would be appriciated
You should probably read https://forum.videohelp.com/viewtopic.php?t=223640 .
At the end of the day, someone can just reauthor your keypad lock out of the picture anyway.
So .... worth it ?If in doubt, Google it. -
hahahaha i think you may have it there!!!!
but in regards to actually helping. i have made the keylock before on a dvd as part of a questionare where each screen asked a question and the answer correct answer gave the next number on the lock ect. i made the lock on adobe encore dvd and yes it took a long time but if you just follow the guide step by step it is not very hard. but if you want it easy then just get dvd lab as i have and it includes it as a plugin. you then just drag it to your dvd project and choose the passcode and it does all the work for you. -
Wifey/GF
Yeah, i always wondered "why" 8)
I can actually see the need sometimes to "want" to protect something from being copied, but these keypad locks and passwords
In the end... it's all futile!!
But i too sometimes try to do things that don't matter, just to see if it can actually be done 8) -
Originally Posted by GINZY
If the wrong digit is pressed on any of the menus it will send them back to the first menu making it a loop so that the first digit must be pressed again. - Don't use switched menus, the links will update automatically and mess the whole thing up.
Standalone DVD recorder - is there and easier way to ensure audio sync?
By dphirschler in forum Video ConversionReplies: 20Last Post: 30th Dec 2009, 02:57 -
Creat DVD with VOB files, without re-encode
By temp759 in forum Authoring (DVD)Replies: 8Last Post: 17th Apr 2009, 09:01 -
creat dvd to fit your tv screen
By projecttemp in forum Video ConversionReplies: 2Last Post: 16th Jul 2008, 07:37 -
How to creat an DVD audio with DVD video together ?
By marcos90 in forum Authoring (DVD)Replies: 4Last Post: 17th Jun 2008, 02:32 -
DVD5 to Mini DVD, Which is the best and easier Software out there ?
By acidcrash in forum DVD RippingReplies: 12Last Post: 29th Aug 2007, 12:25
