Hi I really need help with ShowBiz DVD 2. Everytime I try to write to a disc I get a pop up messege saying not enough free space on drive check temporary folder. I know I have enough space on the disc I only use 2.GG on a 4.0GB disc. What gives? Help
we neeeeeeed more information.
are you making a data dvd? dvd-video from video_ts folder? converting from avi,dv or similiar to dvd? or ? -
I am making a dvd-video from the video_ts folder. The file is in .avi format. I even set the video quality to the lowest setting and still get the not enough free space pop up. Very very frustrating. I hope that helps.
In authoring prog. change temp folder to one with more free space?
Perhaps prog. writes to temp folder then transfers to burner/DVD? -
I think it's saying your actual computer doesn't have enough room, not the DVD.
How much actual free space to you have left on your computer? You need to have a couple of GB free on the actual hard drive to write the DVD.
Also, change the temporary folder location to someplace else, this may help.
You can do that by going up to 'Options' in Showbiz, click 'Temporary Folder', then click 'Browse' and choose (or make) another folder somewhere else on your computer to see if it helps.
(I'm having a whole different unbelievable set of problems with the crappy Showbiz 2 DVD. BUYER BEWARE! I'm currently searching for threads with like problems)......
ShowBiz DVD 2 Error - Failure writing the disc
By smbcingu in forum Authoring (DVD)Replies: 4Last Post: 2nd Jan 2011, 16:34 -
ArcSoft Showbiz DVD 2 Smart Rendering
By zulubase in forum Newbie / General discussionsReplies: 0Last Post: 28th Oct 2009, 21:12 -
ShowBiz DVD 2 problems; can't work with Kodak EasyShare pictures
By KBesq in forum EditingReplies: 0Last Post: 23rd Jul 2007, 19:56 -
Audio Missing when editing file with Showbiz
By hokiehub in forum Authoring (DVD)Replies: 2Last Post: 10th May 2007, 10:46 -
ArcSoft ShowBiz Audio Problem
By KenOBrien in forum Newbie / General discussionsReplies: 0Last Post: 5th May 2007, 06:29
