Is is ALWAYS safe to set DVD Decrypter to burn at MAX, even if it choses a faster speed than the media indicates? I have Maxell DVD+R rated at 8x but DVD Decrypter always indicates 12x. I would be using the burned media in a stand alone DVD player.
I set speed myself. Some dirves let some discs go faster than the rating. In general, stick to the rating, go no faster.
The only exception I would do is YUDEN DVD+R, go ahead and burn than 8x disc at a 12x speed, if you want. Turns out fine in most burners.
Sometimes you may want to even go slower (MCC 16x media, for example, may yield better results at 8x or 12x).Want my help? Ask here! (not via PM!)
Whether 8x or 16x media,I always burn at 4x because it gives a better quality disc (Low PIE and PIF)
~Luke~ -
Yep!! I always set my burn speed manually, and never go over the speed limit listed on the media.
What's the hurry ?? even from 8X to 12X you are saving what ?? a minute or two tops
And even on faster media i still burn at 8X, except DL's which my burner will allow me to burn them up to around 8-12X yet i won't even DARE burn them over the 2.4X rated speed.
Even at $2.00 a pop on sale, i can walk away or do something else on my machines and wait 30 minutes for it to finish burning 8) -
This was incorrect.Originally Posted by laspis59
I used mostly 8x certified media and 4x burn speed was optimal.After having done a little testing with 16x media I found that an 8x burn is optimal.
Usually burn at half the media's certified speed and you will have good results.If you have a drive that can give DVD+/-R/W quality scans then test for yourself to find the best write speed for your specific media.
Jees,I learn more everytime I start up my PC.My brain is becoming the size of a watermelon.
~Luke~
Movie speeds
By drmrsolds in forum Video ConversionReplies: 8Last Post: 16th Nov 2009, 06:35 -
Write Speeds - anything new?
By Mike99 in forum MediaReplies: 22Last Post: 10th Feb 2009, 19:41 -
Burning speeds
By Rogert in forum Newbie / General discussionsReplies: 2Last Post: 1st Sep 2008, 07:28 -
Encoding speeds
By Illusionist in forum ComputerReplies: 13Last Post: 11th Jul 2008, 10:01 -
DVD burner read/write speeds
By ecc in forum Authoring (DVD)Replies: 9Last Post: 13th Apr 2008, 05:49
