    Feb 2006
    Hi all, wonder if someone could help me with the problem i am having with svcd2dvd 2.
    I have been using the software for over a year now and make 10- 20 dvd's per week.
    Recently the software is cutting 6-8 minutes off of the end of a film.
    Today again i have converted an avi to vob using svcd2dvd 2 -
    Format - - Avi
    Duration - -1.36.21
    Bitrate - - 112kbps
    Dimensions - - 640 x 272
    Size - - - 700mb
    I converted it with the software which took around 3 hrs to do and on checking b4 i put the converted files onto disc i only have a run time of 1.29.32 it has yet again cut almost 7 minutes off the end of the film.
    This is now doing my head in so can anyone PLEASE help me with my problem??? ANY help would be greatly appreciated.
    My comp is running winxp and i have all available updates.
    I just dont know what is going on. All i know is that i get pretty peaved when the softeware has taken 3 hrs to complete the conversion only to find the end missing.
    PLEEEEEEEEEEEEEEEEAAAAAAAAAAAAAAAAAAASE could someone help this poor old mum out???
    mumgonemad
  2. Have you checked the reencoded video to make sure you are in fact losing 7 minutes of video, and not just seeing different lengths because of different framerates used? A quick calculation told me going from ~25fps to ~30fps meant speeding up the video by close to your seven minutes.
    Just a guess.
    Feb 2006
    Hi HeinzHarald, thanks for your input.
    Yep i'm sure it's cutting the end off. I have been checking the end of the original avi and the dvd/vob files and it does indeed cut 6-7 minutes off the film.
    It is really puzzeling me as it never used to do it.
    But thanks again heinzharold
    mumgonemad
  4. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Can i see your log please?
    Feb 2006
    Hi chrissyboy, will try to attach 2 log files to this post for you to look at. 2 different films that svcd2dvd has cut the end off of.
    I must add that it doesn't do it with bin files. They convert just fine.
    Look forward to your reply
    mumgonemad
    well as far as i can see my attachment didn't attach so will copy and paste 1 log file here
    ********************* SYSTEM INFORMATION ************************
    ***************************** SVCD2DVD *****************************
    Title: 2.0
    Version: 2.0.2106.31236
    Executable: C:\Program Files\BadgerIT\SVCD2DVD v2\SVCD2DVD.exe
    Executable size: 2.50 MB
    Executable size in bytes: 2625619
    Executable CreationTime: 08/10/2005 16:12:20
    Executable LastWriteTime: 08/02/2006 19:16:23
    Executable LastAccessTime: 08/02/2006 23:28:40
    ************************* Operating System *************************
    Operating System: Microsoft Windows XP Home Edition
    Service Pack: Service Pack 2
    Version : 5.1.2600
    Windows Directory : C:\WINDOWS
    OSLanguage: 1033
    CodeSet: 1252
    CountryCode: 1
    Local: 0409
    Total Physical Memory: 0.99 GB
    Free Physical Memory: 569 MB
    Total Virtual Memory: 1.99 GB
    Free Virtual Memory: 1.96 GB
    ***************************** Computer *****************************
    Computer Manufacturer Name: INTELR
    Computer Model: AWRDACPI
    System Type: X86-based PC
    Computer Name: HOME-E7C64UHWHE
    DomainRole: x2c3419cdc9b8e007
    Number Of Processors: 2
    User Name: HOME-E7C64UHWHE\lynn
    ***************************** Processor ****************************
    Manufacturer: GenuineIntel
    Processor: Intel(R) Pentium(R) 4 CPU 2.80GHz
    Description: x86 Family 15 Model 3 Stepping 3
    CPU Speed: 2.806GHz
    CPU FSB: 200MHz
    L2 Cache Size: 0 bytes
    CPU Speed: 2.806GHz
    CPU FSB: 200MHz
    ***************************** Time Zone ****************************
    Time Zone: (GMT) Greenwich Mean Time : Dublin, Edinburgh, Lisbon, London
    ****************************** VIDEO *******************************
    Name: SAPPHIRE RADEON 9200 ATLANTIS
    Processor: RADEON 9200 AGP (0x5961)
    Mode: 800 x 600 x 4294967296 colors
    Video Ram: 256 MB
    Status: OK
    Name: SAPPHIRE RADEON 9200 ATLANTIS - Secondary
    Mode:
    Video Ram: 256 MB
    Status: OK
    ****************************** Drives *******************************
    DeviceID: C:
    FileSystem: NTFS
    FreeSpace: 53.1 GB
    DeviceID: F:
    FileSystem: NTFS
    FreeSpace: 152 GB
    DeviceID: G:
    FileSystem: FAT32
    FreeSpace: 151 GB
    ********************* END OF SYSTEM INFORMATION ********************
    ************************* ProjectMetaData **************************
    <SVCD2DVD DateTime="08/02/2006 23:31:40"><AssetSet><Asset ID="0b3b7618-e582-4c09-b192-962407c5bd18" Path="G:\My Videos" Filename="The Violation Of Gia Paloma.avi" /></AssetSet><DVDStructure><TitleSet Name="New Movie" PostCmd="" MenuButtonType="0"><MenuButton X1="0" Y1="0" X2="262" Y2="49" FontFamily="Tahoma" FontSize="28" FontStyle="3">Menu Button</MenuButton><Title Name="The Violation Of Gia Paloma.avi" AssetID="0b3b7618-e582-4c09-b192-962407c5bd18" MplexOffset="0" /></TitleSet><DVDMenu TVStandard="PAL" Normal="-1" Highlight="-65536" Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="C:\Program Files\BadgerIT\SVCD2DVD v2\default.jpg" AudioPath="" /></DVDStructure><Settings><General InitialAssetFolder="" InitialDVDFolder="G:\converted" InitialProjectFolder="" DeleteS2DFiles="False" UseDVDShrink="False" /><Menu AudioEncoding="Custom_mpa" DefaultCustomAudioPath="" DefaultCustomImagePath="" TVStandard="PAL" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play All" Loop="True" EncodeVideo2AudioDuration="False" /><Process AudioEncoding="mpa" Chapters="Every 10 mins" SkipMPA48="False" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="False" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" /><Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" /><Burning BurningMethod="NONE" DVDDrive="PIONEER DVD-RW DVR-110D" NeroWriteSpeed="Max" Eject="True" HighDVDCompat="True" VerifyDVD="False" DVDDecrypterPath="C:\Program Files\DVD Decrypter\dvddecrypter.exe" DVDDErase="True" DVDDClose="False" DVDDDontBurn="False" /></Settings></SVCD2DVD>
    Processing assets for DVD creation
    =================== AV Details ===================
    file=G:\My Videos\The Violation Of Gia Paloma.avi
    FormatName=avi
    Num_Frames=143881
    DurationInSecs=4800
    Duration=01:20:00.8
    VideoCodec=mpeg4
    Width=640
    Height=480
    Standard=NTSC
    BitRate=1716
    AudioStreamCount=1
    Audio1SampleRate=44100
    Audio1Codec=mp3
    Audio1BitRate=128
    Audio2SampleRate=-1
    Audio2Codec=NULL
    Audio2BitRate=-1
    AVI2MPG: 7336kbs Full-D1
    23:31:40: Looking for AVI PAR...
    Pass 1/1: Processing The Violation Of Gia Paloma.avi
    23:31:41: ffmpeg version CVS, build 3276800, Copyright (c) 2000-2004 Fabrice Bellard
    23:31:41: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-vhook
    23:31:41: built on Oct 8 2005 16:10:52, gcc: 3.2.3 (mingw special 20030504-1)
    23:31:41: Input #0, avi, from 'G:\My Videos\The Violation Of Gia Paloma.avi':
    23:31:41: Duration: 01:20:00.8, start: 0.000000, bitrate: 1716 kb/s
    23:31:41: Stream #0.0, 29.97 fps: Video: mpeg4, yuv420p, 640x480
    23:31:41: Output #0, dvd, to 'G:\My Videos\The Violation Of Gia Paloma_S2D.mpg':
    23:31:41: Stream #0.0, 29.97 fps: Video: mpeg2video (hq), yuv420p, 720x480, q=1-31, 7336 kb/s
    23:31:41: Stream #0.1: Audio: mp2, 48000 Hz, stereo, 224 kb/s
    23:31:41: Stream mapping:
    23:31:41: Stream #0.0 -> #0.0
    23:31:41: Stream #0.1 -> #0.1
    03:33:02: video:4297749kB audio:131256kB global headers:0kB muxing overhead 1.746919%
    03:33:02: AVI2MPG: done.
    03:33:02: Done: Processing assets for DVD creation
    Authoring DVD Folders
    03:33:02: Creating TitleSet # 1
    03:33:02: SVCD2DVD: DVDfolders
    Generating DVD folders please wait....
    03:33:02: -->: DVDFolders creating VTS
    03:33:02: -->: VTS 01
    03:33:02:
    DVD Folders: Processing G:\My Videos\The Violation Of Gia Paloma_S2D.mpg...
    03:43:53:
    03:45:27:
    03:45:27: Finalising DVD...
    03:45:27: SVCD2DVD: DVDfolders
    03:45:27: -->: DVDFolders creating table of contents
    03:45:27: scanning G:\converted\SVCD2DVD_OUTPUT\VIDEO_TS/VTS_01_0.IFO
    03:45:27: Finalising DVD...Done
    03:45:27: Done: Authoring DVD Folders
  6. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    According to
    DeviceID: G:
    FileSystem: FAT32
    FreeSpace: 151 GB
    your file system is FAT32. FAT32 has a single file limit of 4GB. that is why the encoding stops when this has been reached.
    Solution. Use a differnt drive or convert the G Drive to NTFS which is the prefered file system for XP.
    Feb 2006
    Hi chrissyboy, thankyou very much for the advice. Sorry didn't know about the hard drive it's an external one i brought recently.
    Anyway thankyou very much - i moved everything off drive did a format and changed to NTSC and now NOT having any problems with svcd2dvd.
    Cheers again 4 ur help
    mum
  8. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Cheers mum!
