Ive done it all.... Cant get rid of it. Ive dont the uninstall of 5, then install of 6. Removed 6. Install 6. Remove 6. Reboot. Install 6. You name it...
6.1.1 is installed, but somehow, I think the 5.0.3b DLL is still hanging out?!?!
I did a file search for divx*.* and didnt find divx.dll in windows/system32 after UNinstalling BOTH. Its there upon the reinstall.
Im using avi.NET with Divx 6.1.1 now. However, gspot still indicates the AVI was encoded with 5.0.3b!
Anyone help?
Thanks,
Andrew
Results 1 to 14 of 14
I have been into computers since 1980. Ive been tinkering with DV in one flavor or another since 1990.
from reading what youve written,its indicating what the avi was encoded with,not what your using to watch it?
am i right.?LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant. -
From what Im seeing, yes...
Also, the bitrate feature of avi.NET doesnt appear to be working as expected. I can enter 1.5mbs, and the resulting video is always 4.5mbs, it is stated that 6.0.3 Divx version or newer is needed for avi.NET to function, however since upgrading I cannot see where avi.NET is functioning as expected, possibly due to the wrong Divx CODEC being detected.
Yes, I installed and registered (purchased) 6.1.1, primarily because I wanted to use avi.NET to its full feature advantage. Otherwise, I was happy with 5.0.3 and AGK. (Outputting for viewing on Philips 642).
Im not wanting to FDISK just to fix this, though Im pretty sure that would work.
PLEASE HELP!I have been into computers since 1980. Ive been tinkering with DV in one flavor or another since 1990. -
What gspot is saying about the installed codec...
Summary:
Type:
VFW
Format:
DIVX
Name:
DivX® 6.1.1 Codec (1 Logical CPU)
ID:
vidc.divx
Merit:
0x00200000
Driver File:
quartz.dll --> DivX.dll
Detailed
Source Property Value
DSH 4CC DIVX
VFW Description DivX® 6.1.1 Codec (1 Logical CPU)
"DSH DirectShow CLSID CLSID_AVIDec {CF49D4E0-1115-11CE-B03A-0020AF0BA770}"
REG Driver File C:\WINDOWS\system32\DivX.dll
DSH Friendly Name DivX® 6.1.1 Codec (1 Logical CPU)
- - Function Decoder
REG Merit 0x00200000
VFW Name DivX® Codec
- - Type VFW
HTH,
AndrewI have been into computers since 1980. Ive been tinkering with DV in one flavor or another since 1990. -
in options of gspot,in settings,can you enable Expert Mode: enable codec management.
then go to sytem,list codecs and other filters.
all the codecs should appear,then just right click on them and unregister or register them.-that worked for me when i had a few that were problematic,dont know about now,as my gspot was older,than yours---ooeerr!!!LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant. -
Register/Unregister is greyed out...
Using 'Effective File Search' software, I cannot seam to find any file in c:\programs or c:\windows that has the text string 503b or 5.0.3 in a file that is associated with Divx.
Is there another method to determine what encoder was used to create an AVI, to verify what gspot is reporting?
Thanks,
Ive scanned the registry, but Im doing it again with "Divx503b1828p" now.
So, I may be chasing a ghost here. Doah. I was just looking on the forums at divx.com and there was one post suggesting that same thing.Originally Posted by jagabo
But, my question is, why is gspot showing "Divx503b1828p" for the encoder?? I can see the 4cc being d5, but shouldnt it show that Divx611 was used to encode??
I have gone over the system several times, with about 5 different filter and codec programs, and everything shows Divx 6.1.1 installed, and no reference to Divx 5.
So, I guess I just wasted a lot of time, maybe?
Anyway, that does settle my nerves a bit, I was concerned that my settop 642 would need a new ROM flash to support 6, but doesnt appear that way. Will burn a file and check it out anyway.
Thanks for all the help...
jagabo... Ive come to that conclusion also. Weird, so there it is.
Cant get rid of aliasing
By killerteengohan in forum RestorationReplies: 7Last Post: 8th Feb 2012, 00:33 -
Can't get rid of DivX watermark
By DarrellS in forum Software PlayingReplies: 6Last Post: 28th Mar 2011, 14:27 -
Getting Rid of PC Heat
By adalect in forum ComputerReplies: 29Last Post: 4th Jun 2009, 04:05 -
Getting Rid of Subtitles
By macbuz in forum MacReplies: 4Last Post: 16th Jan 2009, 20:09 -
How to get rid of Windowboxing on a DivX file for Front Row
By hauns in forum MacReplies: 0Last Post: 9th May 2007, 14:44
