Where "capturing" is concerned,what's the difference between these files? VOB, AVI and DVD
Hi mikehende,
That's a very broad question, and can have a wide range of answers.
Explain why you're asking, and what you're trying to do or thinking of doing - this will help define the question better.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
I wish to capture movies from TV and also copy DVD's/movies to my HD then burn back unto blank DVD's, I want the best quality I can have so I will capture from in DVD format but I want to make sure that when I copy a DVD movie that I have the space to burn it back unto a regular 4.7GB blank.
Welcome to the site, mikehende!
My recommendation to you is to read, read and then read some more.
Avail yourself of every guide on video capturing, rendering and authoring, and when you're familiar with some of the tools, come back and read some more.
Of course, questions are always welcome!
Cheers!
TTWC"I've got a present for ya!" - TTWC -
A "DVD" is not a file, it is a type of media. DVD compatibility requires MPG files with specific parameters.
VOB files are one of the types of structures into which files on a DVD are grouped.
AVI can describe many types of files, such as uncompressed, Indeo, Divx, Xvid, dozens more, and more to come.
You could capture to one of many types of AVI for re-encoding to DVD, to MPG, or to DVD-compatible MPG, which is not necessarily the same thing. You cannot capture to VOB.
As suggested, you have some reading to do. -
Where are you capturing to? DVD recorder, VCR, PC etc.Originally Posted by mikehende
Look into ripping, shrinking and burning - there are plenty of tools and guides. This will be using the VOB files on the original DVD.Originally Posted by mikehendeThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
That is capture.Originally Posted by mikehende
That is NOT capture. That's more like ripping.and also copy DVD's/movies to my HD
Then get good equipment.I want the best quality I can have so I will capture from in DVD format
That's something else entirely.but I want to make sure that when I copy a DVD movie that I have the space to burn it back unto a regular 4.7GB blank.
Capturing question.
By ingeborgdot in forum Capturing and VCRReplies: 13Last Post: 26th Jan 2011, 16:33 -
Capturing Question
By Jackf6 in forum Capturing and VCRReplies: 3Last Post: 2nd Jan 2011, 12:46 -
Question about capturing VHS tape to .avi file
By rfdillon in forum Capturing and VCRReplies: 6Last Post: 27th Jul 2008, 01:44 -
question about converting flv file to regular avi type of file
By jimdagys in forum Video ConversionReplies: 4Last Post: 28th Nov 2007, 12:39 -
question about how to use cue file to break big audio file into tracks
By jimdagys in forum AudioReplies: 13Last Post: 12th Oct 2007, 09:40
