Getting on board with DL Burning. Drive was cheap, wish I could say the same for media.
It looks like Verbatim is the brand to use. But I have a question.
Is there really is pro or con's using DVD-R DL over DVD+r DL?
I newer Pioneer with play DVD+-R without issue. My old Panny A120 (7 years old and still going!) Will only play DVD-R's Would like to have the DL disk play on both.
I have heard that the DVD-R DL's must burn all of the 1st layer to work. Would that be a problem if I burned an ISO image with ImageBurn? Or a Main Movie Only burned on DL?
Results 1 to 12 of 12
For the love of God, use hub/core labels on your Recordable Discs!
I have experimented a little with both formats. You are correct in that the entire first layer of the DVD-DL must be burned for it to work. What happens is that the layer is padded if necessary to fill it out. The only reliable way that I know of to burn DVD-DL is to use PgcEdit to make an ISO and then use ImageBurn. The settings of ImageBurn are a little tricky. There is some setting where it says something like "calculate layer break" or "set layer break manually" and you have to set the layer break manually for DVD-DL. This is very poorly explained in a lot of places. I had to do a web search to find this out. The value 2295104 for the layer break usually is OK for DVD-DL (at least for Verbatim) but one or two guys reported having to use different values because DVD Decrypter reported a different number of free sectors in their discs.
It has been reported that Nero cannot properly burn DVD-DL, but I can't confirm that. The discs are too expensive to waste on a test with Nero. I like the format less than DVD+DL. My DVD-DL discs have been consistently problematic for my Philips DVP-642 to play. It will play them, but at random points it freezes for a few seconds before resuming play. -
Pretty much what HatchetMan said.Originally Posted by jntaylor63
Except i don't know about "most burners by default bitset them to DVD-ROM" ?
As alot of burners have to be flashed or use a utility to change the book type.
But i always use +R because i have set my burners to change the booktype to DVD-ROM.
My panasonic dvd recorder only records & plays -R, will NOT read or play a DVD+R, but with the booktype changed to DVD-ROM it reads and plays +R & DL+R perfectly!!
I don't know what kind of burner/s you have but that would be the way to go with +R's. -
Then I should calrify. All dual layer burners that I have used, even ones that do not bitset +R, do bitset +R DL, my Pioneer 108 for example, for better compatibility reasons . But, I have seen some that do not and need flashed to a firmware that will. On the upside to that, usually a hacked firmware that bitsets +R DL will also bitset +R as well
My pioneer 108 never bitset and as far as i know Pioneer are unable to bitset at all.
All the latest Pioneer drives will automatically bitset dual layer discs, even though they don't bitset single layer.
-Brett -
Thanks for the info guys.
How do I change the booktype on my burner to DVD-ROM for DVD+R DL?For the love of God, use hub/core labels on your Recordable Discs! -
Well, from what everyone seems to be saying, dual layer burners automaticaly set DL+R's to dvd-rom, i can't say for sure one way or the other as i have never looked into it and i always flash my drives with custom firmware to set the booktype with sinlge layer +R's as soon as i install them.Originally Posted by jntaylor63
If you want to reflash your drive to set even single layer +R's to ROM you can do a search for the firmware, i can't look because i don't have a clue what kind of a burner you have as nothing is listed in your "computer details" and you have not stated what burner you have
According to Google search results I found at http://www.bitburners.com/Reviews/Hardware/VSO_DVD_recorder_and_media_reliability_report/ -R is compatible with more players than +R, but +RW is more compatible with more palyers than -RW. From my experience with DVD5 media I've found this to be the true although I've not yet done any DL burning.
Need Help with Panasonic DVD-LS83 or DVD-LS86 8" Portable DVD Player!
By Big C in forum Portable VideoReplies: 3Last Post: 1st Aug 2011, 18:35 -
Samsung DVD-HR753 DVD and HDD recorder rejected all my blank DVD
By undangltn in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Mar 2010, 13:34 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 09:14 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 18:59 -
DVD+/-RDL Playback on Yamaha DVD-C750, DV-C6770, and DVD-C950
By Big C in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Aug 2007, 09:59
