What codecs do I need to play Divx?
Oooops... this question has been asd a million times??
I'm lost.
I've done lots and lot of searching.
But... can't decide on what to go for.
I've tried searching on Yahoo and have downloaded a few files.
I haven't installed anything yet - do I really have to install a 15MB file to get the codec I need?
From a previous posting, I was given the following link:
www.divx-digest.com/software/mpeg4codec.html
That codec is 5 years old... do I need something more recent to pl
I've previously heard that generally that you should only install the codecs you need, rather than a zillion all at once?
I'm confused: why is there not one single source to get safe codecs from??
Thanks.
OM
Results 1 to 14 of 14
Here is the official Divx 6 codec http://www.free-codecs.com/download_soft.php?d=936&s=439
ok... happy to go with ffddshow.
but... i've read all sorts of things about not clogging up ur system with loooads of codecs... and dangering causing conflicts??
isn't that what ffddshow will do?
thanks. -
ffdshow isnt that bad, what you gotta worry about is whats called a codec pack...those are BAD BAD BAD......ffdshow basically is a set of direct show filters that can play back your video, and wont really cause any harm.....do NOT install k-lite or angel potion (i know that's probably REALLY old and not even around to speak of any more) or anything else with the words codec pack attatched to it
thanks for the replies.
what about the following:
www.divx.com - comes top of search engine lists.
www.divx-digest.com - comes on first page of search engines.
www.free-codecs.com/download/DivX_Free.htm (it's the 'free' that worries me!).
http://www.xvidmovies.com/codec.
those are what come up if you do a search on yahoo.
maybe i'm being ultra cautious... but are the above OK? -
http://www.koepi.org/xvid.shtml is the correct xvid codec
Which codecs to play .vob files?
By chewie8008 in forum Software PlayingReplies: 21Last Post: 8th Dec 2013, 17:18 -
AVI files with Divx codecs - will they play?
By pooksahib in forum Video ConversionReplies: 7Last Post: 29th Jan 2011, 16:59 -
Multiple Divx codecs?
By Huh...What? in forum Video ConversionReplies: 15Last Post: 16th Dec 2009, 09:44 -
what codecs do i need to play RMVB in WMP?
By set69 in forum Software PlayingReplies: 12Last Post: 12th Feb 2009, 16:57 -
Xvid and Divx Codecs
By Jomapil in forum Newbie / General discussionsReplies: 2Last Post: 29th Jan 2009, 11:42
