What is currently regarded as the best method of transcoding avi's to dvd
in terms of quality and compatability?
The best way that ive found is using nero vision express as it gives me the option of choosing custom bitrates and handles AC3 5.1.
Is there a way to convert just the video to mpeg2 and authoring with the untouched ac3 5.1 later?
As far as i know tmpgenc only handles 2channel ac3 if u have the plugin.
Sure, as to your last question. Encode just the video with TMPGEnc encoder, then add the AC3 audio when you author the DVD. If it has MP3 audio instead, I encode to AC3 2 channel with ffmpeggui and add that in during authoring.
And using a standalone encoder like TMPGEnc or similar is the best way to go. Quick and easy at a lower quality can be done with a program like DivxToDVD. -
how do I author with ac3 5.1?
Do I extract it with virtualdub as a .wav first? -
Yes. But run it thru ac3fix first, just to take out any flaws that may cause problems to the authoring app.
/Mats
ffmpeg can transcode both audios on "dual avi"?
By CactusMan in forum Newbie / General discussionsReplies: 3Last Post: 12th Jan 2012, 07:25 -
transcode avi with cdvc codec to dv sd for editing in final cut
By raulamado in forum MacReplies: 3Last Post: 13th Oct 2008, 02:31 -
x264 encoded mkv/mp4 transcode to xvid encoded avi
By graysky in forum Video ConversionReplies: 4Last Post: 9th Aug 2008, 18:55 -
Beyond TV won't transcode DVD!!
By nikolasmor in forum Authoring (DVD)Replies: 1Last Post: 19th Nov 2007, 10:02 -
possible to transcode DVD to FLV, using a particular subtitle in the output
By YoKnows in forum SubtitleReplies: 1Last Post: 30th Jul 2007, 13:19
