I have some MP4 files I dowloaded and I want to make them MPEG4 to put them on my PMP.Is their a freeware program that will alow me to do this?
I don't get it. mp4 is MPEG-4. You mean you want MPEG-4/mp3 in an avi container or something?
I have some quick time files that I want to put on my Portable media player.They are video podcast off I tunes.Isn't MP4 what apple ues and my player says it plays MPEG4 flies.
mp4 is a standard. Apple use it (although their trailers are all use mov as a container), Nero use it, doesn't make it either of theirs. It is an open standard.
With DVD, etc. players they often use MPEG4 to refer to DivX/XviD/mp3/AC3 avi files. Strickly speaking it isn't MPEG-4. The only thing that is MPEG-4 is the video and I guess mp3 since it is allowed under MPEG-4 specs. Using avi as a container and AC3 are not though.
I'd suggest that you check exactly what your player supports. -
You can use Super, set output to avi, set the output codec to divx. Set the resolution, it depends on the portable player, usually around 320x240. Set audio codec like mp3. Encode.
edit: what container does the portable player support? just divx doesn't say much. what is the portable player? -
Did you have the Creative Zen Vision, or Vision:M? If is i had the same problem.
DVD player with MPEG4 support cannot recognize MP4
By videohalp in forum DVD & Blu-ray PlayersReplies: 2Last Post: 29th Dec 2011, 08:42 -
MP4 editing > Freeware software that will do it!
By Bodh1 in forum Newbie / General discussionsReplies: 10Last Post: 30th Jun 2010, 02:59 -
AVI to mp4 Freeware and VOB to mp4 Freeware
By saucedmike in forum Newbie / General discussionsReplies: 2Last Post: 1st Jan 2008, 02:44 -
Freeware that will take a mp4 and do a one button color restoration?
By andersonmilltexas in forum Newbie / General discussionsReplies: 15Last Post: 21st Dec 2007, 22:46
