I have compiled a dvd with shorts and I install chapters with TDA after burning the dvd certain chapter will begin to play and then after a min or so the image freezes but the time still continues to the end of the chapter. Any insight to this. Thanx all.
I reject your reality
and substitute my own.
- Adam Savage -
- Mythbusters - -
Hi dynamix1,
Did you encode your own MPEG2s for DVD compilation? If so, what bitrate did you use for the video and the audio?
I ask because I had this exact problem. I re-encoded the video at a lower bitrate (around 8,000kbps) and kept the WAV audio (that's always 1,536kbps) and no more problems.
It seems that some DVD players - even good brands, mine was a Toshiba - sometimes stall at high bitrates.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
I had recoded it because they were in different formats. I recoded the audio and video to the highest settings I believe it was 9200. I used tmpegenc 3.0.
- Adam Savage -
- Mythbusters - -
Try re-encoding so that the total is around 8 - 8,500 kbps. If you need a higher video bitrate, encode the audio (instead of WAV) to AC3 - ffmpeggui will do this. I'd recommend against MP2 as this isn't in the NTSC DVD specification.Originally Posted by dynamix1There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
FREEWARE for batch, menu-less authoring of DVDs
By nharikrishna in forum Authoring (DVD)Replies: 6Last Post: 11th Oct 2011, 05:00 -
Standalone player that will play ISO images of DVDs
By whatever911 in forum DVD & Blu-ray PlayersReplies: 16Last Post: 30th Sep 2011, 12:58 -
i need help authoring a dvd. or rather a set of dvds
By TehAnonyMOUSE in forum Authoring (DVD)Replies: 8Last Post: 12th May 2011, 14:01 -
Which authoring tools are good at designing 50+ DVDs
By tripecac in forum Authoring (DVD)Replies: 5Last Post: 12th Aug 2008, 08:13 -
authoring DVDs guide
By aldaco12 in forum Authoring (DVD)Replies: 6Last Post: 18th May 2007, 08:56
