Forgot to mention : D-Vision also has the feature to embed (preserve) the subtitles carried over from MTR/DVD2One extraction, as you're joining the vob files.
Results 31 to 37 of 37
Hi
I'm new to this forum and haven't read all the replies so if I'm repeating someone, I apologize.
Here's what worked for me. I have Mac OS 10.5.7.
I converted the PAL disc in HandBrake 0.9.3 (which is a free download) to an m4v file. I selected video code MPEG-4 (FFmpeg). Framerate (FPS) - I selected 29.97 (NTSC Video).
I sent the m4v file to 4Media DVD Creater (this is not free but I think you can download and try it out). Select your resolution, etc. and you've got an NTSC disc. I converted a concert which is about an hour long and total time was about 1-1/2 hours for the total conversion.
Hope this helps somebody. Looking forward to any feedback.genniebaze -
Which presets settings are we to use? I came to this post from another place (mahalo answers) which quoted this (without telling me) and I'm just curious as to which presets I should be using...Originally Posted by rorschach
I also used handbrake to convert the video I have into an iPod format - did a fantastic job. May try it to do a conversion, but I would like to use a format that does less compression. Otherwise its great (but two transcodes isn't ideal)Originally Posted by genniebaze:: ehmjay. -
if you want quality, use a software that do transcodingOriginally Posted by genniebaze
- jes deinterlacer (free): great to convert framerate PAL <-> NTSC (all frames will be recalculate by interpollation, slow but smooth)
- mpegStreamClip (free): not too bad to convert framerate (with blend, faster but less good)
all other software does duplication or removing of frames (to adapte the source standard to the destination standard, result is jerks!)
so avoid them
byeFor DVD, iPad, HD, connected TV, … iMovie & FCPX? MovieConverter-Studio 3 (01/24/2015) - Handle your camcorder's videos? even in 60p or 60i? do a slow-motion? MovieCam. -
Why are you cross posting? -- https://forum.videohelp.com/topic371043.html
because I had originally posted here a while back and got no response so i started the new thread... only to get responses here
but also because I was trying to get a response from the person who mentinoed using Presets in MPEG Streamclip.:: ehmjay.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
What's the easiest way to convert a PAL DVD to NTSC?
By snafubaby in forum Video ConversionReplies: 3Last Post: 26th Mar 2012, 21:21 -
convert pal dvd to ntsc, but different
By atomicrabbit in forum EditingReplies: 5Last Post: 12th Jan 2008, 04:48 -
Convert PAL 16x9 DVD to NTSC DVD w/ Procoder - Less Image-More Borders Why?
By tubularusa in forum DVD RippingReplies: 15Last Post: 5th Aug 2007, 02:26 -
How to convert PAL DVD to NTSC?
By tomterrifk in forum Newbie / General discussionsReplies: 3Last Post: 18th Jul 2007, 16:35
