I have a whole slew of wmv files I need to convert to a format that can be played on both P2P and Ipod. I'd prefer to convert to just one format as opposed to two to conserve server space. Is this possible?
Thanks!!!
What is the difference between the format P2P accepts and Ipod accepts? From my reading, it seems that the Mpeg4 format the Ipod accepts needs additional processing to be accepted by P2P player - yeah?
Results 1 to 11 of 11
How about SUPER, that might be what you require.
https://www.videohelp.com/tools?tool=SUPER_1 -
GuestNo, I cannot convert to one format that is accepted in PSP and Ipod or no, use this link?Originally Posted by Baldrick
wasn't signed in at the time... let's try this.... the above two posts are mine.
No, I cannot convert to one format that is accepted in PSP and Ipod?Originally Posted by Baldrick
I don't think so because the accepted resolutions, bitrate etc are likely to differ between the two devices. There may be a common accepted profile but it would likely be a compromise.
Well, I was hoping one file would cover both bases but if I've got to convert to two seperate formats, that's what I've got to do... just wanted to make sure before I put double the load on the server...
I'm going to use use Videora iPod Converter to convert wmv files to a format compatible with the iPod player and pspVideo9 to convert wmv files to a format compatible with p2p player.... yeah?
Does anyone know a better way?
Thanks!!! -
might want to check out here: http://www.pqdvd.com/index.html
Maybe email the folks -- as far as I can tell from their site, video for psp is 1 of the formats listed for ipod. They make an ipod version that's more flexible it looks like, but doesn't look like it has the same ability to load psp?
Unable to convert some WMV files to Ipod Touch format - Why?
By tradertt in forum Video ConversionReplies: 14Last Post: 8th Oct 2009, 05:22 -
Does DVDFAB support to convert blue ray dvd to ipod format?
By linda.0p in forum Blu-ray RippingReplies: 1Last Post: 3rd Nov 2008, 03:56 -
Convert audio (music only) stream to Ipod format
By tabcom in forum MacReplies: 7Last Post: 12th Aug 2008, 14:42 -
convert mvs-tsm.r movie format to iPod?
By kieran_92 in forum Video ConversionReplies: 4Last Post: 3rd Aug 2007, 06:26 -
Looking for a tool to convert .ISO to the ipod format.
By xoADAMox in forum Newbie / General discussionsReplies: 4Last Post: 19th Jun 2007, 01:10
