Hello, I'm having a slight problem when creating DVDs, the audio volume jumps every now and then. It goes very loud for a split second then goes back to normal. My DVD player seems to play everything else OK, and when I've burned other DVDs the same thing doesn't happen, so it seems to be something with SVCD2DVD. Does anyone have any ideas on how to fix it? It's not too bad if it only happens very occasionally but on some DVDs I've made it's every few seconds or so.
Many thanks in advance.
Are the source files .mpg or .avi?
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
It seems to happen on both, but it was worse on a DVD I made from MPEG2 files.
The SVCD2DVD DVDs: Do they do the same thing when played on the PC?
They play fine on the PC - so I guess it could be my DVD player. I just tried burning the same DVD on a couple of different discs and the jumps are in the same place each time.
Are you outputing AC3 or MPA audio? Try setting the opposite to the setting you are using.
Increasing Audio volume on AVI/DivX/Xvid with AC3 Audio
By Spacedementia87 in forum User guidesReplies: 21Last Post: 24th Dec 2021, 08:21 -
Increase Audio Volume
By Soixante in forum Authoring (DVD)Replies: 3Last Post: 25th Sep 2010, 17:24 -
Low audio volume
By Daz_uk in forum Capturing and VCRReplies: 0Last Post: 29th Jan 2010, 14:34 -
Sony trv 18 no internal speaker volume, no headphone volume
By websbymark in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 5th Oct 2009, 12:39 -
how to increase the volume of the audio?
By sharmine in forum Newbie / General discussionsReplies: 1Last Post: 22nd Nov 2007, 06:45
