Trying to find out the best video capture software to use...
Any suggestions...?
So far have seen Ulead Video Studio 5.0, Vegas Video & Pinnical 7. Are these good/bad...? Any other suggestions..?
TIA
Well if you check under the Tools section it lists all whole bunch of different software that has the ability to capture stuff. Ie. Avi_Io, Virtual Dub, iuVCR and the list goes on...and I prefer any1 of those 3 above mentioned.
I use Vidcap (or is it Vidcap32). For some reason this really old program works best for me. I get tons of frame drops when I use Virtualdub.
Thanks for the advice guys. I should have been a little clearer as what I ment to ask is which app would you reccomend for capture and editing...
Sorry for the confusion.
TIA
Nik
Best video capture software? Is AVI better for capture? Is TV screen better
By johnharlin in forum Capturing and VCRReplies: 5Last Post: 21st Feb 2011, 08:17 -
Which video capture software??
By DJ12345 in forum Capturing and VCRReplies: 2Last Post: 23rd Feb 2010, 11:42 -
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 20:26 -
By Etherel15 in forum Capturing and VCRReplies: 10Last Post: 7th Sep 2007, 13:13 -
Software to capture everything on my PC monitor as a video (?)
By jimcornetet in forum EditingReplies: 1Last Post: 6th May 2007, 15:54
