hi guys all i'm tryng to do is add some subs to my homade dvd.
all i'm tryng to do is load my vob files on subtitle workshop, but the instant i load them the program tells me there is an error and needs to shut down.
i tried to load the ifo in subtitle creator with the same results :error shuts down. i copied the dvd files on my hard drive with dvd shrink at first,than i tried dvd decrypter with the same results.on advice of admin i converted the vob files to mpeg with -vob2mpg- but the same thing happen.what's going on?why these programs (subtitle creator/sub workshop) gives me error when tryng to load these files? anyone please?![]()
ps:i even demuxed the files and remuxed them with no results!
Check the guides on subtitles. If you're reauthoring, have to demux the sup files and either use as is, or OCR to text & eventually re-render for DVD. Or look at SCC Tools site for info on extracting/converting CC. Or if new DVD without subs, check tools section for programs that let you create from scratch.
Subtitle Creator error: Input string not in correct format
By kpic in forum SubtitleReplies: 6Last Post: 31st May 2013, 03:17 -
subtitle workshop crashes when loading video
By stem300 in forum SubtitleReplies: 0Last Post: 29th Dec 2011, 15:37 -
Subtitle Workshop crashes upon loading subs
By mystic818 in forum SubtitleReplies: 9Last Post: 17th Mar 2011, 06:51 -
Error loading .sup files to GfD?
By michcio in forum SubtitleReplies: 0Last Post: 13th Dec 2009, 12:08 -
Subtitle Workshop 4 crashes when loading subtitle file
By Batou in forum SubtitleReplies: 0Last Post: 26th Mar 2009, 06:57
