Results 1 to 30 of 46
  1. I have a mpeg file. Once imported into Premiere, the audio will play fine. However, the video will play at a faster speed.
    I used TMPGEnc to de-multiplex the mpeg into m1v and mp2 and tried to import it into Premiere. Premiere complains "File Format no supported."
    Any way to edit this mpeg file?
    Thanks!
    premiere is a video editor and not an authoring tool. moving yooooooooooou.
    mpeg2 or mpeg1 ? i would just convert to huffyuv or dv-avi with virtualdubmpeg2. or frameserve.
  3. I think Premiere needs a plugin to use MPEG2 sources.
    Apr 2002
    Oskeeweewee Ontario
    Yeah, like this plugin that i'd love to try out..
    Sounds promising..Almost too good to be true $><$
  5. Originally Posted by jagabo
    Which plugin is needed?
    The MainConcept one appears to be an encoder and is quite expensive.
    Thanks!
    Apr 2002
    Oskeeweewee Ontario
    Since Premiere is an .AVI editor you'd have to use a third party plugin like the one i mentioned earlier..
    The link that i pointed to you is a plugin that allows for MPEG editing on the timeline..The same as you would for .AVI..Yes, it's expensive, but if it works like they claim, then it would be a Godsend for professional users..
    This is an impressive task, and not quite "mainstream", since Mpeg wasn't intended for editing.
    Yes, it's expensive..
    I'll see if i can dig you up the guides on freeware options for the same tasks, but time and quality will take a hit..
    On a side note, i've got a local video store that will offer me potential editing of their DVD's..Since they do transfers (and nothing else), some customers require editing..
    It's very difficult to explain the nuances of editing MPEG..Therefore, this tool would be the ticket...
    I can't justify the cost, especially when nobody wants to shell out the money...
    Apr 2002
    Oskeeweewee Ontario
    Here you go...
    Enjoy!!!
    Muuwahahahaha.
    Good luck!!!
    Apr 2002
    Oskeeweewee Ontario
    IIRC, i tried this awhile back, and it wasn't successfull with the Premiere Pro version...
    Oct 2005
    Premiere 2.0 there is no need for an plugin works fine without the plugin 2.0 supports mpegs
    Apr 2002
    Oskeeweewee Ontario
    I don't see anything on their website to support this..
    Am i missing something??
    Oct 2005
    Hey Pijetro I have the full version Of 2.0 and I can honesty say that 2.0 supports native mpeg editing here some a couple of links to some of the forums check it out
    http://www.adobeforums.com/cgi-bin/webx?13@543.hEGyfj8hTKc.2@.3bbe63cc/0
    http://www.adobeforums.com/cgi-bin/webx?14@543.hEGyfj8hTKc.0@.3bbe2790
    but there is No MPEG support in Trial so check it out take my word for this man i have 2.0 full version and it lets me edit everything i havent come across anything that has gave me an prob please my man goolge it Peace out
    Nov 2005
    AFAIK Prem, Vegas etc will allow import of mpg2 on the timeline, & when it doesn't it's an issue of conflicting codecs &/or support files (splitters etc.). That's not to say any of them will handle it well, but...
    Otherwise there's a few frameserving alternatives, including DGIndex -> Avisynth or VFAPI, & VFAPI (while not as good as Avisynth) will almost certainly work.
    Might also check out Debugmode frameserver or even Avisynth to V/Dub frameserving to Prem, or biting the bullet and rendering mjpeg or DV avi.
  13. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    If this was true wouldn't it have been included in all the prerelease hype Adobe has been spewing for months? Why would they be keeping this a secret?
    I think they should license and include the Mainconcept MPeg2 timeline plug-in to put Premiere firmly back in the game.
    But have they?
    http://www.kiva.org/about
    Apr 2002
    Oskeeweewee Ontario
    You totally took the words out of my mouth...
    Although even earlier versions of Premiere accepted .M2V streams, it was never designed to do so, and it was hit and miss as far as output goes..
    I wish the Mpeg plugin was cheaper to get my hands on..What a shame (assuming it does as they claim)..
    But i'll also have to trust mikayd's claim that the Mpegs are being somehow recognized....
    Maybe it's an easter egg for us, and Adobe doesn't have to pay a licensing fee??
    Just a guess..
  15. Member edDV's Avatar
    Mar 2004
    Just a guess..
    Adobe Premiere has imported MPeg for some time. It needs to be "conformed" or decompressed to the project timeline format. This is true for all other RGB or YUV native editors. Nothing new here.
    The Mainconcept MPeg2 plug-in allows direct editing of the MPeg2 file in a similar way to the how DV is handled. Only areas that are affected by filtering are decompressed. A simple cuts only edit would be lossless.
    Oct 2005
    Hey You guys sorry if I wasn’t any help but I can promise 2.0 supports mpeg the main concept plug-in want work with 2.0 I have tried and it gives an error but hey don’t take my word for it ask someone else that has spent dame near 1000 dollars on a program. And when you import an mpeg file there is no need to 2.0 to conform the audio. But hey sorry it I'm not any help but it works like a charm for me.
    Well this is what I found in the help file of 2.0
    Maybe this well helps you. You guys just have to be positive
    Supported file formats for import
    Adobe Premiere Pro can import a number of video and audio formats. It also supports 10-bit color depth, necessary for editing standard and high-definition footage.
    File format support is provided by plug-in software modules. Most of these software modules are installed automatically with Adobe Premiere Pro.
    Supported video and animation file formats
    You can import any of the following types of video and animation files:
    ASF
    Type 2 AVI
    MPEG, MPE, MPG, M2V
    QuickTime (MOV; requires QuickTime player)
    DLX
    Windows Media File (WMV)
    Animated GIF
    Filmstrip (FLM)
    Note: Type 1 AVI clips must be rendered before they can be previewed from a DV device. To render a Type 1 AVI clip, add it to a sequence in a DV project, and build a preview file of that section of the Timeline panel.
    Supported audio file formats
    You can import any of the following types of audio files:
    Audio Interchange File Format (AIFF)
    AVI
    MP3,
    MPEG, MPG
    WAVE (WAV)
    WMA
    Supported still-image file formats
    You can import any of the following types of still-image files:
    Adobe Illustrator (AI)
    Adobe Photoshop (PSD)
    Bitmap (BMP, DIB, RLE)
    EPS
    GIF
    ICO
    JPEG, JPE, JPG, JFIF
    PCX
    PICT, PIC, PCT
    Portable Network Graphics (PNG)
    PTL, PRTL (Adobe Title Designer)
    Targa (TGA, ICB, VDA, VST)
    TIFF
    PSQ
    Note: You can import layered Illustrator and Photoshop files as sequences.
    Supported video project file formats
    You can import any of the following types of video project files:
    Adobe Premiere 6.0 or 6.5 (PPJ)
    Adobe Premiere Pro (PRPROJ)
    Advanced Authoring Format (AAF)
    After Effects Project (AEP)
    EDL
    PLB
    Peace Out
  17. Member edDV's Avatar
    Mar 2004
    What project formats are supported?
    If direct MPeg editing is supported, you will see it in the project formats.
  18. Member
    Apr 2002
    Oskeeweewee Ontario
    Yo mikayd, where did you get this bomb from??
    Sounds awesome, and worth every penny for the software....
    So that's what's probably happening..
    The Mpeg Plugin is being loaded upon installation..
    I'll have to explore on the Adobe forums..
    ASF
    Type 2 AVI
    MPEG, MPE, MPG, M2V
    DLX
    Animated GIF
    Filmstrip (FLM)
    Again mikayd........thanx..I'm quite impressed..
  19. Member edDV's Avatar
    Mar 2004
    Here you go.
    MPeg is not on the list. What this means is all of the import formats above must be decompressed and converted to YUV or RGB.
    http://www.adobe.com/products/premiere/supportedformats.html
    http://www.adobe.com/products/premiere/pdfs/premiere_faq.pdf
    Oct 2005
    edDv That list that you have above is in way incorrect it it dosent have avi neither or wmv nethier but i can asure you it dose i dont know what to tell you guys that still dont belive that 2.0 indeed supports mpeg but hey good louck on another program but man 2.0 is how do you say this kicking some ass lol good luck to you all and that list i posted earlier came right out of the help file of 2.0 dowload the trial and do an sreach for mpeg and you will see but good day EdDv
  21. Member edDV's Avatar
    Mar 2004
    You still aren't understanding the difference between importable formats and native formats. Premiere Pro internally can operate in YUV or RGB color space in the formats listed above. Those formats can pass through Premiere Pro without a decompression - recompression generation loss.
    No "avi" has no relevance. It is a container.
    No wmv is not natively supported, it must be decompressed.
  22. Member
    Nov 2005
    http://www.adobe.com/support/techdocs/332612.html is from the knowledgebase rather then ad bs.
  23. Member edDV's Avatar
    Mar 2004
    "This table lists the file formats that Adobe Premiere Pro can import and export."
    You still don't get it? The Mpeg gets decompressed and recompressed.
    There is nothing new about this. Premiere has been importing MPeg since at least version 6 and exporting since version 6.5.
    You should go back and read the description of the Mainconcept MPeg2 editing plug in. It spells it all out.
    http://www.mainconcept.com/mpeg_pro.shtml
  24. Member
    Oct 2005
    Hey man just get 2.0 and you’ll see for your self its kind of hard to tell someone with 2.0 that it dose and it doesn’t support these file formats I mean man 2.0 is rocking it let me ask you something do you even have 2.if so look I the help file man its not that hard but good luck to anybody that has listened to me and every body else hell lets all go and edit some mpegs after all that’s what the guy who posted is having an problem with 2.0 there isn’t an problem not for me who all here has an problem 2.0 yes or no will do
    Peace out
  25. I would like to clarify my initial questions.
    I CAN import mpeg file in premiere pro 1.5. However, only the audio track plays fine. The video track plays at a fast speed.
    I CAN NOT import m1v file in premiere pro 1.5.
    I guess I need to find space to decompress the file.
  26. Member pchan's Avatar
    Mar 2003
    Singapore
    Premiere is not good at handling MPEG2 format. I am having the same problem with Premiere 6.5. Try export short MPEG2 clip to MPEG2. If it plays fine, then it should be OK. I find it much easier to edit with MPEG Video Wizard
  27. Member
    Hey man just get 2.0 and youll see for your self its kinda hard to tell someone with 2.0 that it dose and it doent support these file formats i mean man 2.0 is rocking it let me ask you somethnig do you even have 2.0of so look i the help file man its not that hard but good luck to anybody that has lostend to me and every body else hell lets all go and edit some mpegs after all thats what the guy who posted is haveing an problem with 2.0 there isent an problem not for me who all here has an problem 2.0 yes or no will do
    Peace out
    is that english?
  28. export is not a problem with version 7 and above.
    Peace out
    is that english?
  29. Member edDV's Avatar
    Mar 2004
    Are you saying you had a problem with the Adobe-Mainconcept MPeg encoder in Version 6.5 ?
